sounds like a plan
good luck.
in a terminal window, if you want to copy something - itâs usually âShift + Ctrl + Câ - because Ctrl+C is usually reserved for cancelling / aborting commandsâŚ
Thanks Dan, Iâll use that when I go back in to Linux.
Pat
Hi Cord,
I did exactly as you suggested: âonce you have a window that looks like the one above, you should be able to click on the entry for zim. near the top left of the window that opens there should be an install button
cordâ
And it worked perfectly. A big thank you.
Pat
