Hello Friends
According with man passwd exists the following information:
-d, --delete
Delete a user's password (make it empty).
This is a quick way to disable a password for an account.
It will set the named account passwordless.
For experimental purposes was created a test user as sudo adduser testuser and later was executed the following command:
sudo passwd -d testuser
Therefore the su - testuser works without requesting any password as expected
Just being curious, if this approach exists, is because exists at least one reason to accomplish this approach. Therefore
Question
- Why/When to use
passwd -d?
