Hi all, ![]()
I ran into some weird problem as of late.
For my second virtual machine - Bodhi Linux - I now opted for the command-line approach in order to get rid of the permission error virt-manager threw at me with my debian vm.
So according to kvm virtualization - Permission error in virtual machine manager - Ask Ubuntu I also can do it thus:
sudo chown libvirt-qemu:libvirt-qemu <image-file>
That I did and thus could easily import the existing img-file for Bodhi. ![]()
The vm starts alright but when logging in I“m presented with an error message:
Error found when loading /home/rosika2/.xprofile:
xrandr: cannot find output āVirtual-0ā
Hmmā¦![]()
I then started Bodhi using the i3 tiling window manager and thus at least could get a smaller window in which I could make use of the terminal.
xrandr -q informed me about Virtual-0 being used. So I changed into /home/rosika2/ and looked at .xprofile:
cat .xprofile
#!/bin/sh
xrandr --newmode "1696x953_60.00" 133.75 1696 1800 1976 2256 953 956 966 989 -hsync +vsync
xrandr --addmode Virtual-0 1696x953_60.00
Hmm⦠xrandr -q said āVirtual-0 connected primary [ā¦]ā.
So I changed the config file to use āVirtual-1ā.
I rebooted and indeed everything“s o.k. now
ā¦
⦠as long as I make use of the i3 tiling window manager.
However the problem remains when trying to use the Moksha DE. Still I“m presented with a popup. It says:
Display output is not active
I guess there“s a dedicated config file for Moksha which needs changing but I don“t know where to start here. ![]()
Does anybody have a clue and can help me ![]()
Thanks a lot in advance.
