Right.
If you do nothing with the file, it cant do anything to you
Hi Neville, ![]()
thanks for the confiirmation. These were my thoughts as well.
The only thing I did with it was moving it to trash. ![]()
Thanks again and cheers from Rosika ![]()
Thanks for that link, just run it against my own site, all clear as I had hoped and expected but never though of checking before
Hi Paul, ![]()
you“re welcome.
I“m glad you find virustotal useful.
I“m delighted to hear that. ![]()
BTW:
Apart from checking URLs you can also upload a file from your local PC, in case you need a second opinion (in addition to e.g. clamscan).
In this case apply the āChoose Fileā button and select the file in question.
There“s a limit in size, of course. The popup window says it“s 650 MB.
All the best from Rosika ![]()
