Hi!
I cannot hear any audio from my Smansung TV connected via HDMA on my HP ProBook, mounting a Ubuntu 18.04.4 LTS.
I can’t even see the audio device in the devices list. Some infos
uname -a
Linux jsbach 4.15.0-96-generic #97-Ubuntu SMP Wed Apr 1 03:25:46 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
Following this help
https://itsfoss.com/how-to-fix-no-sound-through-hdmi-in-external-monitor-in-ubuntu/
I couldn’t resolve my problem.
aplay -l
**** Lista di PLAYBACK dispositivi hardware ****
scheda 0: PCH [HDA Intel PCH], dispositivo 0: CX20724 Analog [CX20724 Analog]
Sottoperiferiche: 0/1
Sottoperiferica #0: subdevice #0
$ sudo pactl list | grep HDMI
$ sudo lsmod | grep HDMI
I regularly see the computer screen on my Samsung TV via HDMI but no sound at all (only the bulti-in speakers work); not even the audio output listed as sound card.
What else can I do?
Thx
Akito
18 April 2020 12:20
2
sound, pulseaudio, hdmi
When a TV is connected to computer running elementary OS/Ubuntu/Linux Mint through HDMI cable, it is observed that audio will not pass through the HDMI. Eventually, the audio keeps playing in the computer's speakers. Video will still work good in...
Best answer: I had to disable the Intel Display Audio driver under Device Manager / sound, video ..., restart the computer, and then re-enable it. This caused the playback device to appear in the playback devices list (control panel / sound /...
https://forums.linuxmint.com/viewtopic.php?t=250454
Also please fill out the template given below:
Welcome to our community.
Before you post a question or request help, please read this FAQ in case your question is already answered. If it is not, use the template for opening a request for help, so you can be helped quicker and more efficiently, which is probably one of your primary goals when addressing your issue, as well.
If you want to post a request for help, please use the template below!
Q1: How do I install Ubuntu, Kubuntu, Xubuntu, Ubuntu MATE, Linux Mint, Peppermint OS, LXLE or a…
