I created this post so as not to put an off-topic post in the
Anyone daily drive KDE? topic.
Hi @berninghausen,
Jimmy (@Akatama) and Cane (@TrekJunky) are right: I had to set up at least 2 virtual desktops to get the virtual desktops switcher icon (widget) on the panel.
These are the steps I took to add the virtual desktops ( I’m using KDE Plasma 5.27.8):
Open System Settings (Application Laucher → System Settings):
Select the Workspace Behavior:
Select the Virtual Desktops and click the Add button to add the virtual desktops:
The icon (widget) for switching virtual desktops in the panel is only visible if you have at least 2 virtual desktops.
I hope you manage to add the virtual desktops.
If you have any questions, just ask, and we’ll try to help.
