Hi all, ![]()
I´m using Debian Buster in a virtual machine (KVM/qemu/virt-manager).
As I´m currently still on Debian 10 (Buster) it´s time to upgrade it to the latest version (Bookworm).
I tried to do so yesterday but my attempt failed, I´m sorry to say. ![]()
I wanted to upgrade the system directly from Buster to Bookworm. I´m not sure it was the right thing to do.
Should I have perhaps taken the route: Buster —> Bullseye —> Bookworm ![]()
Is it in theory possible to skip a version with the inline upgrade ![]()
As my first attempt failed I tried another method: upgrade to Bullseye first, but I seem to have run out of virtual disk space.
I need to enlarge it first.
Curiously enough the small disk space wasn´t the issue with my first attempt. Here I ran into difficulties of a different kind.
My steps were the following:
- take a snapshot of the VM (which proved to be the right thing to do)
- in Debian: unhold any kept-back packages
sudo apt updatesudo apt upgrade- reboot the system
sudo apt dist-upgradesudo sed -i 's/buster/bullseye/g' /etc/apt/sources.listsudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list.d/*.listsudo apt updatesudo apt upgradesudo apt full-upgrade- reboot the system
sudo apt autoremovesudo apt clean
The first problem I ran into was:
The step “sudo apt update” after the sources have been changed to bookworm… I got the following message:
Hit:1 http://deb.anydesk.com all InRelease
Hit:2 http://deb.debian.org/debian bookworm InRelease
Ign:3 http://security.debian.org/debian-security bookworm/updates InRelease
Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
Err:5 http://security.debian.org/debian-security bookworm/updates Release
404 Not Found [IP: 146.75.118.132 80]
Hit:6 https://download.docker.com/linux/debian bookworm InRelease
Reading package lists... Done
E: The repository 'http://security.debian.org/debian-security bookworm/updates Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
To address this issue, I temporarily disabled the security updates repository for Bookworm while still proceeding with the upgrade.
Once the correct repository is available, I may re-enable it, I guess.
So I commented out the lines:
# deb http://security.debian.org/debian-security bookworm/updates main
# deb-src http://security.debian.org/debian-security bookworm/updates main
It worked well but I finally ran into the main problem:
After sudo apt full-upgrade (it downloaded all the packages but couldn´t install them): This was the last message I received:
"/usr/bin/perl: error while loading shared libraries: libcrypt.so.1: cannot open shared object
file: No such file or directory
dpkg: Fehler beim Bearbeiten des Paketes libc6:amd64 (--configure):
»installiertes libc6:amd64-Skript des Paketes post-installation«-Unterprozess gab den Fehler
wert 127 zurück
Fehler traten auf beim Bearbeiten von:
libc6:amd64
Fehler: Zeitüberschreitung wurde erreicht
needrestart is being skipped since dpkg has failed". After that I wanted to restart but the system won´t start anymore.
Sorry, it´s in German.
Basically it´s this:
- Error processing the package libc6:amd64 (–configure)
- post-installation sub-process: error 127
- libc6:amd64: error editing / timeout
I rebooted but couldn´t log in anymore. ![]()
Hmm, as this procedure failed, what would you suggest is the wisest course for doing an inline upgrade from Debian Buster to Bookworm ![]()
Many thanks in advance
Cheers from Rosika ![]()
