@nevj :
Hi again, ![]()
I just tried to enlarge Debian´s qcow2 image by 20G so that I could give the inline upgrade another try.
It seems to have failed though. ![]()
Here´s what I did:
qemu-img resize virtualdebian.img +20Gsudo modprobe nbd max_part=8sudo qemu-nbd -c /dev/nbd0 virtualdebian.imggparted /dev/nbd0- then I performed the resize action from within
gparted# see protocol below sudo qemu-nbd -d /dev/nbd0sudo rmmod nbd
So far so good, I thought. But I was still sceptical, as gparted still showed that 20GB of unallocated space.
But here´s the protocol of what gparted did:
GParted 1.3.1
configuration --enable-libparted-dmraid --enable-online-resize
libparted 3.4
Device: /dev/nbd0
Model: Unknown
Serial:
Sector size: 512
Total sectors: 104857600
Heads: 255
Sectors/track: 2
Cylinders: 205603
Partition table: msdos
Partition Type Start End Flags Partition Name File System Label Mount Point
/dev/nbd0p1 Primary 2048 21606399 boot ext4
/dev/nbd0p2 Extended 21608446 62912511 extended
/dev/nbd0p5 Logical 21608448 23607295 linux-swap
/dev/nbd0p6 Logical 23609344 62912511 ext4
Grow /dev/nbd0p2 from 19.70 GiB to 39.70 GiB 00:00:01 ( SUCCESS )
calibrate /dev/nbd0p2 00:00:00 ( SUCCESS )
path: /dev/nbd0p2 (partition)
start: 21608446
end: 62912511
size: 41304066 (19.70 GiB)
grow partition from 19.70 GiB to 39.70 GiB 00:00:01 ( SUCCESS )
old start: 21608446
old end: 62912511
old size: 41304066 (19.70 GiB)
new start: 21608446
new end: 104857599
new size: 83249154 (39.70 GiB)
According to the protocol the action was successful.
I don´t quite get it. The disk size was more than 40GB before. So it should be over 60GB now.
Here´s what the Debian VM said after having started it:
rosika2@debian ~> df -h
Dateisystem Größe Benutzt Verf. Verw% Eingehängt auf
udev 475M 0 475M 0% /dev
tmpfs 99M 4,8M 95M 5% /run
/dev/vda1 11G 7,7G 1,9G 81% /
tmpfs 494M 144K 494M 1% /dev/shm
tmpfs 5,0M 4,0K 5,0M 1% /run/lock
tmpfs 494M 0 494M 0% /sys/fs/cgroup
/dev/loop0 114M 114M 0 100% /snap/core/13308
/dev/loop1 62M 62M 0 100% /snap/core20/1518
/dev/loop3 102M 102M 0 100% /snap/lxd/23155
/dev/loop2 387M 387M 0 100% /snap/anbox/213
/dev/vda6 19G 973M 17G 6% /home
mount-tag 35G 26G 7,3G 78% /mnt/mymount
tmpfs 99M 4,0K 99M 1% /run/user/114
tmpfs 99M 0 99M 0% /run/user/1000
/dev/vda1 is 11GB and /dev/vda6 is 19GB in size…
I don´t know what might have gone wrong despite the “Success” messages provided by gparted.
Cheers from Rosika ![]()
P.S.:
However this is what sfdisk says:
rosika2@debian ~> sudo sfdisk -l
Disk /dev/vda: 50 GiB, 53687091200 bytes, 104857600 sectors
Disklabel type: dos
Disk identifier: 0x4f7a63d0
Device Boot Start End Sectors Size Id Type
/dev/vda1 * 2048 21606399 21604352 10,3G 83 Linux
/dev/vda2 21608446 104857599 83249154 39,7G 5 Extended
/dev/vda5 21608448 23607295 1998848 976M 82 Linux swap / Solaris
/dev/vda6 23609344 62912511 39303168 18,8G 83 Linux
So /dev/vda2 is the one that has grown by 20GB.
But df -h doesn´t list it.
P.S.2:
Here´s what gparted says now:
