I am having issues on my new home server running Fedora WS 39. (Unresponsive sometimes, have rebooted a few times after updates to ensure that was not causing problems, and hard to RDP into at times-- sometimes I get the error “connection reset by peer” and cannot remote without rebooting.
As it is, I have to use a different app to remote into the server (as it is currently headless) than the ones I am familiar with, but it just seems the system was great until this week. Granted, I have not had a lot of time to spend on it, as I have taken on a new fulltime client in my accounting work.
I am trying to troubleshoot what exactly is causing issues and decided to first try logging into a different desktop environment (sans Wayland) but noticed I must not have any installed since there are no options at sign in.
I am a bit confused with all the “available environment groups” so I thought I would just install one I am familiar with and ran:
sudo dnf install @kde-desktop-environment
But it returned errors:
No match for group package "gimp-heif-plugin"
Error:
Problem 1: problem with installed package libswscale-free-6.1.1-3.fc39.x86_64
- package ffmpeg-libs-6.0-16.fc39.x86_64 from rpmfusion-free conflicts with libswscale-free provided by libswscale-free-6.1.1-3.fc39.x86_64 from @System
- package ffmpeg-libs-6.0-16.fc39.x86_64 from rpmfusion-free conflicts with libswscale-free provided by libswscale-free-6.0-11.fc39.x86_64 from fedora
- package ffmpeg-libs-6.0-16.fc39.x86_64 from rpmfusion-free conflicts with libswscale-free provided by libswscale-free-6.1.1-3.fc39.x86_64 from updates
- package ffmpeg-6.0-16.fc39.x86_64 from rpmfusion-free requires ffmpeg-libs(x86-64) = 6.0-16.fc39, but none of the providers can be installed
- conflicting requests
- package ffmpeg-6.1.1-5.fc39.x86_64 from rpmfusion-free-updates requires ffmpeg-libs(x86-64) = 6.1.1-5.fc39, but none of the providers can be installed
- package ffmpeg-libs-6.1.1-5.fc39.x86_64 from rpmfusion-free-updates conflicts with libswscale-free provided by libswscale-free-6.1.1-3.fc39.x86_64 from @System
- package ffmpeg-libs-6.1.1-5.fc39.x86_64 from rpmfusion-free-updates conflicts with libswscale-free provided by libswscale-free-6.0-11.fc39.x86_64 from fedora
- package ffmpeg-libs-6.1.1-5.fc39.x86_64 from rpmfusion-free-updates conflicts with libswscale-free provided by libswscale-free-6.1.1-3.fc39.x86_64 from updates
Problem 2: problem with installed package firefox-124.0-1.fc39.x86_64
- package ffmpeg-libs-6.0-16.fc39.i686 from rpmfusion-free conflicts with libavcodec-free provided by libavcodec-free-6.0-11.fc39.x86_64 from fedora
- package ffmpeg-libs-6.0-16.fc39.x86_64 from rpmfusion-free conflicts with libavcodec-free provided by libavcodec-free-6.0-11.fc39.x86_64 from fedora
- package ffmpeg-libs-6.1.1-5.fc39.i686 from rpmfusion-free-updates conflicts with libavcodec-free provided by libavcodec-free-6.0-11.fc39.x86_64 from fedora
- package ffmpeg-libs-6.1.1-5.fc39.x86_64 from rpmfusion-free-updates conflicts with libavcodec-free provided by libavcodec-free-6.0-11.fc39.x86_64 from fedora
- problem with installed package libavcodec-free-6.1.1-3.fc39.x86_64
- package ffmpeg-libs-6.0-16.fc39.i686 from rpmfusion-free conflicts with libavcodec-free provided by libavcodec-free-6.1.1-3.fc39.x86_64 from updates
- package ffmpeg-libs-6.0-16.fc39.x86_64 from rpmfusion-free conflicts with libavcodec-free provided by libavcodec-free-6.1.1-3.fc39.x86_64 from updates
- package ffmpeg-libs-6.1.1-5.fc39.i686 from rpmfusion-free-updates conflicts with libavcodec-free provided by libavcodec-free-6.1.1-3.fc39.x86_64 from updates
- package ffmpeg-libs-6.1.1-5.fc39.x86_64 from rpmfusion-free-updates conflicts with libavcodec-free provided by libavcodec-free-6.1.1-3.fc39.x86_64 from updates
- package ffmpeg-libs-6.0-16.fc39.i686 from rpmfusion-free conflicts with libavcodec-free provided by libavcodec-free-6.1.1-3.fc39.x86_64 from @System
- package ffmpeg-libs-6.0-16.fc39.x86_64 from rpmfusion-free conflicts with libavcodec-free provided by libavcodec-free-6.1.1-3.fc39.x86_64 from @System
- package ffmpeg-libs-6.1.1-5.fc39.i686 from rpmfusion-free-updates conflicts with libavcodec-free provided by libavcodec-free-6.1.1-3.fc39.x86_64 from @System
- package ffmpeg-libs-6.1.1-5.fc39.x86_64 from rpmfusion-free-updates conflicts with libavcodec-free provided by libavcodec-free-6.1.1-3.fc39.x86_64 from @System
(try to add '--allowerasing' to command line to replace conflicting packages or '--skip-broken' to skip uninstallable packages)
Since I am new to Fedora, what is rpmfusion-free? Which seems to be conflicting with my ability to install any desktops as I got the same results with @cinnamon-desktop.
Any suggestions on troubleshooting the system are welcome. Definitely would like to have options for logging into different DEs, though. And if I continue to have issues with the RDP method of access, I may have to hook up a permanent monitor, keyboard & mouse, but would like to keep it headless.
Thanks,
Sheila Flanagan
