So, I am new to Linux in general.
I have an HP Pavilion x360 notebook and I wanted to make the step from Windows to Linux.
Because I still sometimes need Windows for work related stuff, I made a dual boot on my notebook with Windows 10 and Linux Mint 19.3 Cinnamon.
Everything works great, except for 1 thing: sound.
Audio works fine through headphones, just not through the speakers.
I followed the steps I found on the webpage How To Fix No Sound in Ubuntu And Linux Mint and it did solve the issue finally.
I powered the notebook off and powered it back on the next day, and booted to Windows 10 for work.
I had audio through the speakers in Windows all day without problems.
After work was done, I rebooted to Linux Mint, and no audio is coming out of the speakers.
I connected headphones to test, and that is working fine.
I disconnected the headphones, but still no audio from the speakers.
So it has been working for just one evening.
I performed the steps from the website again, but this time it did not fix my audio issues.
Does anyone have some additional steps I could do to get it working again?
Thanks!
edit:
After reading the “Read before you post” here is some additional information
Where do I configure the default output device?
When I go to Preferences > Sound, and I unplug my headphones, I see only 1 device: Speakers Built-in Audio.
When I go to Terminal > Alsamixer, and I press F6 to select the sound card, I see that it is set to “- (Default)”
I to change it to “0 HDA Intel PCH” and press the Enter key.
But there is still no sound then.
The speaker volume in Alsamixer is 100 and in the bottom it shows “OO” and not “MM” so it is not muted.
The strangest thing happened. I didn’t change anything, but when I powered on my notebook this morning, the audio was working again through the speakers.
What I am not happy with though, is that I don’t understand WHY is started working again.
I’m afraid to power my notebook off now!
It feels a little bit random, do you know what I mean?
Is there anything I can do to check what is different?
Are there any settings windows I should take screenshots of, to compare with when the audio decides to stop working again?
Screenshots are always super helpful. I would advise making some screenshots of the audio settings, when you click on the speaker icon on the bottom right, when being on the desktop. Then it will be clear what devices are available and selected.
Hello rvh.
Well, that’s an old story… there’s no such thing as “perfect software/OSs”.
I can tell you the same thing: I use Dropbox on my Ububtu-Mint.
Now, here comes the question:
Why sometimes Linux boots up without the Dropbox running 'though it’s set up to auto-start?
It’s a rare thing but it happens!
You may as well be a victim of the same imperfections.
I had same problem on my gaming Laptop running Linux Mint 20. Click the sound icon in your taskbar or panel. Left click Audio Mixer. Click the tab that says output sounds and make sure the speaker Icon’s bar is on if it isn’t it’ll have a line going through it to say it is muted. If this occurs again just follow the same procedure as above. When Mint gets switched off with headphones on and then booted back up with speakers, it seems to get confused for some reason. Just go back into Audio Mixer or pulse audio volume control in menu/sound and video and make sure the speaker in output settings is not muted. Play a music track or video track before hand to test if you have sound or not.
I read that when you boot into Ubuntu from power off, sound works. If you reboot from windows into ubuntu, the sound chipset is left on a bogus state. I have this same problem on pavillion x360 and I only solved by turning it off before entering ubuntu. Haven’t found a good fix yet.
This can happen not only to the sound. The reason can be found in the way Windows was shut down previously. If Windows is completely powered off, i.e. no Fast Boot, no Suspend/Sleep, no Hibernate, no other Sleep magic, then the alternative OS will work just fine. All one has to do is to shut down Windows properly, without all the hibernation magic activated.
I somehow experimented with installing two systems on one hard drive - it was extremely problematic. It is more convenient when 2 hard drives are installed or there is simply a second computer for a different operating system.
