Have rebooted to Windows 10 to double-check, and sure enough, right-click for wireless mouse does not work on Kubuntu 22.10 (even after updates and reboots).
First time i encounter such an issue with a Linux desktop.
@danielson ,
Have you looked at the mouse configuration menu?
It may be on some strange setting? Like 2 button mouse for example.
Got it!
Switching to X11 Plasma Wayland did the trick, phew!
Nice way to force you to use Wayland
Is Wayland that ābadā?
Thatās what many people sayā¦but āforcingā you to switch to it is really bad.
Only tried it once in Void/KDE. It had a few hitches, so I stayed with Xorg.
I suspect it will be improving rapidly because Wayland is the future and is under rapid devlopment.
On the other hand it puzzles me why Xorg would suddenly fail to operate a mouse? Xorg has been stable for years, almost decades.
Maybe, it would be a good question to ask on Ubuntu forum?
There are some smart guys there. I never liked Ubuntu or any of the buntus including their DEās, KDE, Gnome and the others. I think it is a great system but only if other devs put their hands on it and make it better, like Mint. But, only my opinionā¦
Wayland KICKS ARSEā¦
I only donāt use it 'cause I canāt live without Synergy KVM (pro)⦠Same deal with Barrier⦠(neither software KVM work with Wayland compositor)
Saw something where you can make the Synergy client work under Wayland, but it looks like too much hardworkā¦
Seeing that this suggestion to post to Kubuntu forum is subordinate to initial postā¦
First, i donāt like the disposition, nor feel a certain āwarmthā at their forum.
Second, guys here a savvy and cordial.
Must admit that Kubuntu 22.10 is lightweight on RAM (1.3Gs) and good on CPU usage (except when playing videos in the browser, but thatās everywhere right)! Thinking of using Freetube app more for this last reason.
Fast or slow, right-click does nothing.
Left does, but options are quite limited.
My post was addressed to Neville because he was āpuzzledā by this, my only point was if we have a specific problem with our Chevy then we wonāt take it to a Honda dealer to fix it.
I didnāt feel comfortable many years ago at Ubuntu forum either, too many regulations, editing usersā posts, warnings to make questions short, etc.
Anyway, I found this:
https://www.reddit.com/r/kde/comments/a1cu6y/help_rightclicking_on_desktop_doesnt_show_context/
Itās old but the problem looks similar.
I suppose you already tried to use a different mouse and it didnāt work either.
OK, that bug is irrelevent to your issue.
How is Wayland going? Any issues there?
Just fine on Wayland. ![]()
@danielson ,
Hi ,
Lets have another try. I had a look in my KDE/Void system. It is kde-5.26.0_1. My right button works.
In the file ~/.config/plasma-org.kde.plasma.desktop-appletsrc
the first three lines should look like this
[ActionPlugins][0]
RightButton;NoModifier=org.kde.contextmenu
wheel:Vertical;NoModifier=org.kde.switchdesktop
If the word contextmenu is something else, change it to contextmenu , then reboot and see what happens.
There is also this
If right click not working that may be difficult. Does anyone know how to get the background menu in KDE without a right click?
Logging out after initial installation gives two options:
X11 and Plasma Wayland.
Logging into Plasma Wayland allows right-click with all the usual options.
And the mouse settings are as per initial screenshot i posted here.
It is clear that X11 does not have right-click option for the desktop.
Oddly enough, right-click toolbar to access ācustomizeā and modify Firefox works fine.
Btw, not sure where to look for ~/.config/plasma-org.kde.plasma.desktop-appletsrc
I posted a link above about both questions. Post is old, but still KDE. It also has links that talk about it further more.
@shamu -Got lost in that thread.
Alt-D Alt-S does nothing for me.
and the link
didnāt seem have any pertinent info.
would be interesting, but donāt know where to find the folder/file.
But i guess you didnāt read my previous about thatā¦
Besides⦠if Wayland does the trick, why should i bother going back to X11 which seems to be a retro move?
