No matter what I tried, when booting to ubuntu 20.04 LTS I can have to press the numlock key twice before it turns on . How do I manage this if I want that numlock on when entering my password during start up ?
Any help is welcome .
Give this a shot.
I clicked on the link “How to enable numlock at boot time for login screen?”
Place command with init scripts
sudo sed -i 's|^exit 0.*$|# Numlock enable\n[ -x /usr/bin/numlockx ]
\&\& numlockx on\n\nexit 0|' /etc/rc.local
but there is no /etc/rc.local file in ubuntu 20.04 LTS,
there are only resembling files under /etc/ :
drwxr-xr-x 2 root root 4,0K dec 3 13:10 rc0.d
drwxr-xr-x 2 root root 4,0K dec 3 13:10 rc1.d
drwxr-xr-x 2 root root 4,0K dec 3 13:10 rc2.d
drwxr-xr-x 2 root root 4,0K dec 3 13:10 rc3.d
drwxr-xr-x 2 root root 4,0K dec 3 13:10 rc4.d
drwxr-xr-x 2 root root 4,0K dec 3 13:10 rc5.d
drwxr-xr-x 2 root root 4,0K dec 3 13:10 rc6.d
drwxr-xr-x 2 root root 4,0K okt 28 09:16 rcS.d
next solution was :
Enabling NumLock from startx
If you are not using a graphical display manager then add the following line to /etc/X11/xinit/xinitrc
/usr/bin/numlockx on
But that was already there in my xinitrc file.
The next solution was :
Enabling NumLock from lightdm configuration
In Ubuntu 14.04 the above methods of running numlockx don’t work. It can be run by changing configuration of LightDM display manager. Edit /usr/share/lightdm/lightdm.conf.d/50-unity-greeter.conf file and add the following line at the end:
greeter-setup-script=/usr/bin/numlockx on
there was no 50-unity-greeter.conf file, but a 50-ubuntu.conf file as only file
I edited that file and added the above line, with numlock staying off when rebooting .
the next solution was this :
Enabling NumLock for Virtual Consoles (TTYs)
If you use the virtual consoles regularly, then you will quite likely want to have numlock on for the TTYs after boot up. The status of numlock/scroll-lock/capslock can be manipulated with the setleds command. One way to guarantee that numlock will be turned on after bootup for the TTYs is to run setleds via rc.local (a script run after every runlevel change; which in particular runs after booting up). To do so add something similar to the following in the file /etc/rc.local
# Turn Numlock on for the TTYs:
for tty in /dev/tty[1-6]; do
/usr/bin/setleds -D +num < $tty
done
But, again, as in the first solution, there is no /etc/rc.local file in my Ubuntu 20.04 .
Next solution is :
Enable NumLock in KDE
From the K Menu, launch System Settings and click on Keyboard (Edgy users: K Menu → System Settings → Keyboard and Mouse → Keyboard). You can see in the middle section the options for “NumLock on KDE Startup”, where you can choose to Turn On, Turn Off, or Leave Unchanged. Select “Turn On” to turn NumLock on at startup.
I have turned the settings program, but there is no possibility to turn on Numlock, there is not a “Keyboard” option, only a “Keyboard Shortcuts” option in which there is nothing for changing Numlock.
I hope someone can help me with this, should be a simple solution somewhere, no ?
Awaiting your remarks, I will leave it for the moment now.
Henk Vanneste.
Perhaps you looked in the wrong place:
Dear Mina,
I am NOT on Windows, but on Ubuntu Linux 20.04 LTS,
it has a totaly other settings program .
Henk Vanneste .
This is Kubuntu (KDE). I was referring to:
Dear Mina,
I think Kubuntu is the only Ubuntu flavour that uses KDE, I am not sure, I will look at it later this afternoon (Brussels time) .
Thank you for trying to help me .
Henk .
There’s also Neon. Both are actually pretty similar.
The conclusion is that it’s a flaw in Ubuntu 20.04 :
it can not be done as far as I know .
2022-01-28T13:38:00Z
Henk.
One last stupid question: Have you checked that numlockx is actually installed on your computer?
Have you tried: sudo apt install numlockx ?
Yes, I already installed numlockx long ago,
I just checked it, it is the latest version .
Thanks for your support, Mina, and have a good year .
Henk .
@hankbonk: I reached the end of my wisdom here…
Me too, for such a simple thing, it’s ridiculous that we spent so much time on it .
I flagged it to make the forum monitoring people aware of this and look into it further .
Regards,
Hankbonk (Henk Vanneste, Belgium) .
Sadly you did not say what make or model computer you have …
This may (or not) help by changing the bios setting
Many laptops have that setting in the BIOS.
Different attack
The PC Desktop is a HP Compaq Pro 4300 SFF .
And I forgot to mentio, it, but I did change the BIOS setting for the numlock to on :
Thanks for your post,
Regards,
Henk Vanneste, aka Hankbonk .
Ok thanks
Is the keyboard cable (usb Or ps2) or WiFi
Is it the standard one sold by the makers of the computer
Do you have access to another keyboard to test if same action occurs
Some keyboards language are reversed qwerty against azerty so the action is different, when installing it does a check of that, could you have selected the Wong one ?
If you auto detect it can choose different against the correct one… had a similar problem with a French Mac which was French Canadian not French France… same language but slightly different layout
It’s unusual to have to switch 2 times to activate
