Post your desktop(s)!
Thanks for the heads up! I haven’t had any problems with it in the make.conf but now I know where to look if there’s any problems. I might change it to package.use though…
Edit: wiki says wayland is global flag: Wayland - Gentoo Wiki
Installation
USE flags
Global
Several packages are aware of the global wayland USE flag.
Local
USE flags for dev-libs/wayland Wayland protocol libraries
doc Add extra documentation (API, Javadoc, etc). It is recommended to enable per package instead of globally
test Enable dependencies and/or preparations necessary to run tests (usually controlled by FEATURES=test but can be toggled independently)
Yea I know, if one is running systemd, it might be a global flag, but I run OpenRC and I keep it as a local flag. Usually if one will use the --pretend when compiling packages, it will point you to what flag to use.
Not everyone loves Wayland. Have you seen this discussion?
My laptop is running openrc so it might be better to take the flag from make.conf. my desktop has systemd so I leave it as is. Thanks!
You have to remember that use flags put in package.use will override the flags in make.conf. If you run emerge --info, you will see a lot of use flags, but not all have been enabled. Also the use of the keyword
~amd64 will also require more use flags to be set. The use of use flags can be iffy at times and not well documented. If you are not having issues, then leave it be!!!
Ok, I’ll leave it for now. If something happens later I try that flag first.
I changed from Xorg because of the issues with Nvidia GPU after kernel updates. I didn’t always remember to do the process (mount /efi, grub-mkconfig etc) when kernel was updated and next boot stuck because of the wrong driver for the GPU or grub issues. I have moved to gentoo-kernel-bin and with Wayland never had any issues after kernel update. My /efi is always mounted nowadays.
I have read that Xorg has also some security flaws which Wayland doesn’t. Can’t remember what.
Yes, I believe Gentoo will eventually move to Wayland!! That being said, the machine I have Gentoo running on can not run with the efi partition, or even a gpt HDD, so I am still using msdos with a /boot partition, which also has to mounted. So I am still using xorg and the gentoo-kernel-bin with the dist-kernel and dracut use flags set in make.conf.
We need to chat more often about Gentoo!!!
Sounds fun! Yeah, let’s chat sometime and not spoil this thread
There’s nothing very special going on here. Fedora 40 KDE Spin using the Breeze Dark theme and Kora icon set. My wallpaper is the Bing daily image which I enjoy as it’s always fresh and often gives me something to read up on.
Once I get settled on Fedora 41 (installing the beta tonight) I plan to change up the panel layout and themes.
You might be nearly the only one here who uses Fedora.
Do you have any take on where it differes from Debian-based distros?
Maybe you could give us a summary.?
The only difference I’ve seen in a Fedora installation is the use of RPM packages and DNF commands instead of APT. Once installed, it’s pretty transparent and works pretty well.
Yes, I expected that.
I guess what I was really chasing was some info from a regular Fedora user about how reliable the people who make its releases are.?
Do upgrades always work , like in Debian, or are there hitches?
In my short experience, the occasional updates always work without problems. I’ve never used it long enough to encounter a version upgrade. If I did, I would likely flush and reinstall.
After watching this forum for several years, I think a large percentage or even the majority of problems rise from the version upgrade process. I would always recommend against upgrading–back up your data, flush/format, and reinstall. Further, used computers are too cheap and easily obtained to not be used. The second biggest source of problems is dual-booting.
Looks like I am a problem user. I do both inline upgrades and dual boots.
Today I’m on my laptop in the back seat of my mother-in-law’s SUV. The laptop is plugged into an outlet in the back seat. I have my cell phone tethered to the laptop using USB-C. Sometimes it’s 4G and sometimes it’s 5G and sometimes the signal fades as we drive.
Here is my “desktop” on my laptop. A nice picture of Iowa, where I live.
Here is a screen shot of a speedtest now that we are near Des Moines and on 5G.
There is no roadway to that house in the middle of a field?
You could not buy those internet speeds here.
That is a barn on a former homestead. Now it’s in the middle of a field. Not sure why they didn’t just tear down the barn instead of planting around it.
@pdecker
Did some work with the Bungee Corp up in Council Bluff a few years back!!!
My Void/Xfce desktop
Deer in our front paddock.
Xfce has the interesting habit of making a desktop icon for every partition it detects.
