I hope someone here can help with this as it is rather urgent. I am currently typing up a talk on ancient Egypt that I am going to give in the near future and half way through the document it is suddenly displaying very tiny print. Does anyone know why this could happen?
can you post a screenshot?
I am sorry to say that I do not know how to take a screen shot and I have been using Linux for five years and Windows for many years before that. I had another look at the page I was typing and already I discovered a work round. the last things I typed before the problem occurred was Ramses 1st â 11th - and of course the st and th were in a smaller font size automatically so what I typed after that was also very small. I erased them and typed the next line of text and then went back again and reinserted the 1st and 11th. I do not know why this happens but at least I know what to do in the future if the situation arises again. Thanks for the quick reply though.
What about the PrintScreen button?
I use the mate screenshot utility and shutter for screenshots.
In English language, it is a common practice to write 1st with st in small fonts on the top. LibreOffice did the correct thing by (possibly) automatically converting it to that format.
As far as solving the problem goes, I suggest use the right arrow key to move to the next white space after âstâ and start typing letters here. This might work.
In most of the mainstream distros, the PrtScn button takes a screenshot by default.
As for the issue in Libre, see abhishekâs reply above.
expanding a bit on what @abhishek explained, i found that writer was converting these ordinal number suffixes to superscript which you can see in the toolbar as the letter a with a smaller b beside and above it like so:
in my trial, writer stopped converting to superscript after i hit the space bar. have you tried saving the document, closing writer and then continuing with editing? if yours continues to convert, it seems like you have a couple of options.
if the way you have been doing it works for you, it makes sense to continue. another way is to turn off the conversion formatting. in the Tools menu there is an AutoCorrect submenu. the last item on that menu is AutoCorrect Options. there is a tab in that window titled Localized Options which looks like this:
deselecting the bottom two options in front of âFormat ordinal number suffixesâ gets writer to stop converting the suffixes.
if you feel like the superscript is helpful and isnât occurring so often that this options is burdensome, you can switch back to regular font by pressing shift + ctrl + p as indicated in the first screenshot before you start typing again.
@cpast, under Linux Mint Cinnamon you can find Screenshot under Accessories.
I run Linux Mint Cinnamon, and the PrintScreen button works for me.
I tried that but it obviously did not make any difference but know matter I found a simple work round. I just deleted the 1st - 11th, typed the next sentence and then went back and inserted the deleted text again. That worked fine.
I have found it now but never even realised it was there. Never had to use it before. Thanks
Yeah sounds obvious but as I had never used it before I did not even know it was there. I know where it is now so thanks all for your help.
I did save the document, and close writer but nothing changed. It is odd that I had been typing all the Dynasties relevant to my talk the same way and the problem did not occur, only when I wrote two consecutively did the problem show up. There is a Libre Office manual that I saw advertised in Linux Magazine so I tried to buy in on line only to find out that it is not sold to Australia which I though was very odd. I tried Amazon and they said the same thing. Most annoying.
This is a feature that drives me to a rage several times a day! And swear, a lot, in an open plan officeâŚ
In nearly EVERYTHING these days where you can type formatted text, there is computer software making arbitrary decisions about what your intentions might be :
Me : types â:â
Computer : âno you didnât really want a colon, you really wanted to type a sideways emoji smiley, because I know you better than you doâŚâ
Me : types âctrl + Zâ (undo)
Me : âyou @%$#ing computer! - I wanted a %#$ing colon character!â
Five minutes later
Me : types â(SMB)â (in an email about windows file sharing), and keeps typing awayâŚ
Computer : âno you didnât really want to type (SMB), you really wanted to type â(SMâ then a sideways emoji smiley wearing sunglasses, because I know you better than you doâŚâ
Me : reaches for sledgehammerâŚ
Only kidding - but it does seem all pervasive⌠I spend so much time undoing (or backspacing if Iâm too late and have lost that particular undo âstepâ I wanted to undo) and backspacing, whatever time these features were designed to save, they actually cost me more, exponentially⌠I can touch type - I did typing in high school in the 1970âs (on manuals and IBM golfball electrics), Iâd much rather just power through with the ascii / ansi characters, then go back later and format⌠I almost NEVER want to format as I type (or even spell check for that matter).
And - it seems even harder to turn off in Libre Office than it does in MS Word⌠well itâs obfuscated deeper into the configuration than with Microsoftâs âcompetitorâ anyway, from memory⌠I hate having to try and find where itâs buried when I need to turn it off (I might bookmark this forum post)⌠really needs a big button somewhere âturn off ALL big brother features from this applicationâ.
My little slightly exaggerated anecdote above, is me typing emails in Microsoft Outlook web client (in Chromium)âŚ
Even this forumâs sofware âdiscourseâ tries to be too clever by half
(thinking â:â means you want to type a smiley). Dang! It even does 66 99 quotation marks ![]()
Related/might help someone: Had 45 minute waste of time with â- - - -â conversion to a solid line full length by hitting âenter.â
Could not delete the line normally and every time Iâd get it erased and hit âenterâ it would show up again above the new line. . and every time âenterâ hit, another line. âToolsâ Autocorrect options no help. Online help no help I could find.
Finally noticed by accident upper drop-down - âassigns stylesâŚâ said something I didnât recognize - I changed it to âdefault styleâ and Writer worked normally again.
It had âchanged itselfâ perhaps somehow when I did â- - -â immediately under a line instead of with at least one space between like I normally do. ?
I think we all have lots of annoyances and anecdotes to tell about autocorrect functions.
I curse the hell out of Outlook regularly (have to use it on work)âŚ
(Photo: Metaweb/GNU Free Documentation License)
The greatest of the 21st century bugbears that drive me to first world distraction!
Autocorrect, like communism, was designed to work perfectly, in a perfect world, but turned out to be a grotesque fantasy
(and that was an intended smiley !)
Even this forum (Discourse default behaviour) insists "that colon you just typed, we know you, better than you do, and we KNOW you wanted to turn it into an emoji, because humans NEVER use colons for anything else but emoji, thatâs what they were invented forâŚ."
and if Discourse is bad? Try the most recent âbuildsâ of Office 365, it barely even asks, e.g. if Iâm manually typing a numbered list, using e.g. A), then B), O365 insists I want to insert a smiling emoji wearing sunglasses, is this even appropriate in an enterprise business oriented product?
Well, I use colons ALL the time, for what they were originally intended for, way back in antiquity, preceding an explanation or definition, or preceding a list (e.g. a bulleted or numbered list)âŚ
Oh well⌠rant overâŚ
These things need a big red or blue (please donât make it green or yellow, because Iâm colour blind!) button to TURN off all smartarse-artistry!
Iâve said it before somewhere here on this forum, my method, when typing a bunch of information, is to just type it, hammer away on the keyboard - then once the guts of the thing is in there, i.e. the main body of text, then review it and format it after the factâŚ
