I dont think i have seen a Swedish keyboard before. Thanks.
But whey two A keys ?
The history of why keyboards are constructed around letter layout is interesting and when you add a different language to use.
I switch between french and english without thinking. But accents in words always catches me out.
Why
Ete becomes été and not ètè when said i cannot hear the difference. Also in some words if its in capitals (uppercase) the doint always use. ETE in some books but others change to ÉTÉ.
Thats really interesting, some french keyboards have the extra accented letter but not all.
When you install a new version of linux on a macine it normally detects your region when connected to the net, lmde detects your language at install, then offers the keyboard it detects. I always test as well before moving on as I did a apple keyboard and an ordissimo keyboard both were none standard and the detection had not picked up. It used to ask where is y, do you have £ or euro symbol, the list of possibilities is massive.
That’s true, but the default character set for HTML was originally specified as ISO-8859-1.
rfc 2070 began the process of relaxing that for the more-international HTML 2.0, and rfc 5987 put UTF-8 and ISO-8859-1 on equal footing for HTTP encoding (which isn’t the same as HTML encoding), but there’s still a lot of code out there that defaults to Latin1 for HTTP and HTML unless, or sometimes even if, explicitly told otherwise.
I asked that question because the man page of txt2html said it converted latin1 to html by default
--eight_bit_clean | -8 If false, convert Latin-1 characters to HTML entities. If true, .....
and if that parameter was set it did some fiddle with the eighth bit ?
If true, this conversion is disabled.
From that I have no idea what the parameter does.?
Man pages are often like that… precise but unintelligable.
Man pages may also be out of date
I think we know this much… @Rosika 's original html was not Latin1 because txt2html should have worked if it was Latin1.
Why the parameter made it work is a mystery to me.
There are varieties of Latin . If you mean the way the Romans spoke, no.
No more than any of us speak Middle English.
Textbook Latin yes. Church Latin yes
All I can tell is that I used the “–eight_bit_clean” parameter on two sets of files:
my test file “Hope it´ll be working”, which I entered in an ordinary text editior (I guess it was gedit
a set of exported html files (some e-mails exported from thunderbird)
As mentioned earlier I got the suggestion for using this parameter by a member of the ubuntuusers forum. (see my post #11).
He actually replied to another member of the forum and I took up the suggestion.
Yes - versus “classical Latin” as taught in some schools… and universities… and used, along with ancient Greek to give “scientific names” to organisms…
There was a great series about ancient “prehistoric” Rome called Romulus (it aired here on the SBS channel) - all the dialog is in “reconstructed” ancient Latin… Although what became Latin was heavily influenced by other languages, including Etruscan…
