Question regarding /etc/apt/sources.list and support period
Hi Neville, :wave:
thanks so much for your latest post.
Very interesting info indeed. :+1:
I see. As I was intrigued by that I took a look at DistroWatch.com: MX Linux and the entry under ā€œInit Softwareā€ is:
systemd,
SysV
So youĀ“re certainly right in your statement. I really admire those people who are able of programming/coding such difficult ā€œscenariosā€. :blush:
It“s the weirdest thing but it seems that my Debian doesn“t have the respective entry at all:
rosika2@debian ~> ll /var/log | grep journal
rosika2@debian ~>
In contrast to that my Lubuntu main system yields this:
rosika@rosika-10159 ~> ll /var/log | grep journal
drwxr-sr-x+ 3 root       systemd-journal 4,0K Jan 20  2021 journal
BTW:
for accessing logs I make use of ksystemlog but have to admit I never tried it with the systemd-journal.
P.S.:
for anyone interested:
ksystemlog
https://userbase.kde.org/KSystemLog
https://docs.kde.org/trunk5/en/ksystemlog/ksystemlog/ksystemlog.pdf
I think there must be a way of turning journal on or off … in systemd somewhere?
My Debian 11 has /var/log/journal and there are files inside it, but it also has the readable files in /var/log ?
What I find strange is that some systems have both the readable log files and rhe systemd journal? Are they doing it all twice?
I prefer the readable log files. Old habits die hard.
for accessing logs I make use of `ksystemlog` but have to admit I never tried it with the systemd-journal.
Thank you. I guess that is a KDE app. Not experienced in KDE but am looking at it (with MX) at the moment.It is a big learning curve.
Hi again, Neville, :wave:
I was looking around a bit and I think I found a hint as to why there“s no journal in /var/log in Debian.
On How to Use journalctl to Analyze Logs in Linux | Atlantic.Net it says:
By default, journal logs are enabled and stores log data at /run/log/journal/.
But, since logs are deleted automatically after a system reboot, you will need to configure Journal to store all logs permanently.
That seems to be the case with my Debian system. :blush:
The article refers to Ubuntu server, so it seems to be the same there.
On my Lubuntu machine the following procedure has - as it seems - already been taken care of:
First, create a directory to store the Journal log:
mkdir /var/log/journal
Next, set proper ownership with the following command:
chown -R root:systemd-journal /var/log/journal
Next, edit the journald default configuration file /etc/systemd/journald.conf and define your new directory:
nano /etc/systemd/journald.conf
Change the following line:
Storage=persistent
Save and close the file, then restart the systemd-journald service to apply the changes:
systemctl restart systemd-journald
You can now check the /var/log/journal directory:
ls -l /var/log/journal
You should see the following output:
drwxr-xr-x 2 root systemd-journal 4096 Apr 21 11:35 97bcb1f0d9aa4b339adefc87f1332d04
Tha“t pretty clear so far it seems.
In order to view the logs collected by the journald daemon one has to make use of the journalctl command:
man journalctl
lists all the available options…
Trying to use lnav (https://lnav.org/ ) for that journal only displays gibberish output, so it has to be journalctl indeed, as it seems. :blush:
Well, that“s one thing more I have learnt now. Very interesting indeed. :slightly_smiling_face:
Yes, KDE apps were something new for me on Lubuntu, too.
I just installed the log viewer with
sudo apt install kdeadmin
which gave me some tools, among them kde-config-cron and ksystemlog.
UPDATE:
I found out lnav can indeed display the journal of systemd:
journalctl | lnav -q
I tried it out and it works perfectly. :blush:
(source: lnav › Wiki › ubuntuusers.de # in German)
Many greetings
@Rosika ,
Thank you, that clarifies a whole range of things.
I find it difficult to imagine why one would want a journal that does not survive a reboot?
As you probably know this topic is part of the systemd controversey. People object that systemd keeps its logfiles in a form which is not viewable as a text file. Debian seems to be having a ā€˜bet each way’ and doing both.
Thank you
Hi Neville, :wave:
you“re welcome. I“m glad I was able to shed some light on some aspects.
In the process of looking things up I“ve learnt quite a bit myself. :blush:
Oh, thanks for the the clarification.
IĀ“ve often heard about people not being particularly fond of systemd but wasnĀ“t clear about the exact reasons…
Have a nice Sunday and many greetings.
The biggest issue seems to be systemd goes against the Unix mantra that a program should do one thing and do it well.
If it had remained just an init system, I think most people would be happy.
It has become much more than an init system, eg interfering with log files, and here it has gone against another Unix mantra - ie that all system files should be visible and editable as normal text files.
We dont want to relive the controversy. Just filling you in
Hi Neville, :wave:
thank you so much for providing your insights. :heart:
I see now. That“s really good to know.
IĀ“ve always been wondering why people often debate about whether a system should use systemd or an alternative…
Now I get the picture. :+1:
Thanks again, Neville.
