Question regarding kernel panic
Or the machine is cold… colder also means smaller according to heat expansion, so the connection may be looser…
(My ideas are just shots in the dark… :smiley: )
elements 25a2 is a disk @Rosika told us in the first post.
so it looks like disk or usb hardware issues.
Hi all and thank you so much for your many responses, :heart:
You´re all so kind.
@JoelA :
Thanks you for your suggestion. That might be it (I´m afraid).
@kovacslt :
Uh, uh. I´ m going to have to do some research on it first.
It´s not the kind of thing I particularly like to do… :neutral_face: .
Also: thanks for the link. I will read through the article.
On the contrary, László.
I use a standing desk for all of my equipment. Once I got all devices wired there´s no need to move anything at all. It´s pretty static that way. It´s been this way for months.
Thanks for your suggestion though.
Well, that certainly is the case.
As it´s getting colder by the day (winter is approaching) the machine certainly is colder than during summer time.
Of course the temperature varies (more or less slightly) on a daily basis. Right now it´s 52°F (11.1°C) here.
@nevj :
That´s my external HDD where the Linux Lite OS installation resides.
I already did that. No errors there.
Thanks a lot, Neville.
@easyt50 :
thanks so much to as well, Howard.
Great. Thanks.
I also spent a lot of time researching that error message.
Many results, as with you, but none of them really seemed to help me.
There is an EFI partition but is not on the external HDD but on the internal one.
It was recognized at the installation time of Linux Lite and refers to the WIN8.1 setup on the internal disk.
So I don´t think the statement applies here.
Thank you for providing so many paths to try out. I´ll see what I can do.
At least for the next few days I´ll probably go down that path.
In fact that´s the most curious thing of all:
The 2nd attempt worked immediately, and I didn´t even touch any cable or any of the peripherals. :thinking:
Today it worked successfully right from the start.
Hmm, it almost seems that way, doesn´t it?
I wonder why…
Thanks, of course I´ll report back as soon as I come up with anything new.
@ all:
Well, most of you have pointed out that the CMOS battery might be worth replacing.
That of course is one of the scenarios I dread the most. :fearful:
I´ve never tinkered with hardware, except for peripherals, of course.
Here are some things to consider:
  • So I would have to open the chassis of the PC.
  • Then I´d have to find out where the CMOS battery is
  • I hope it´s not soldered on. That would be catastrophic. :scream:
  • I´d have to replace it. How would I know what kind it is beforehand :question:
    I already have some new ‘CR2032’ cells available (3V). I hope that´s the correct type, but I can´t be sure.
  • Do I need antistatic wrist-band/-mat :question:
    I don´t have that. Would have to get hold of it first
Oh dear, oh dear. All that doesn´t sound good.
The PC is 10 ys of age now. Might the CMOS battery already be running low?
I was of the opinion that a CMOS battery running low would make itself be noticed by some other signs, like beeping sounds at boot time or the PC losing it´s accurate time.
None of this is the case.
I was thinking: perhaps I shouldn´t shut down the computer completely but let it be in standby to avoid the boot process.
But this doesn´t seem to be realistic, as I might have to reboot after a kernel update anyway…
… besides: wouldn´t the PC consume more energy this way :question:
Thank you so much to all of you for your kind help.
P.S.:
@JoelA :
I just finished reading the article you kindly provided. Thanks again.
It´s very informative but makes me wonder whether I can do it… :thinking: .
Their final words are:
Remember, you also need to rearrange your laptop’s or computer’s BIOS settings. You have to enter the date and time after successfully booting up your device.
Hmm, I wonder what that means.
Well, I get the part regarding date and time, but what about “BIOS settings” in general?
Would I have to look through all of the BIOS pages beforehand and take notes?
I changed the UEFI to legacy mode quite a while ago. Would that be reset as well?
Going through BIOS and taking notes is a wise idea if you are concerned ( I would just take pictures with my phone real quick) I’ve had computers in the past that nothing in the BIOS changed & others that went back to default. More than likely yours is still set to the default settings unless you changed them in the past. Like changing it to legacy.
As far as the symptoms- it all depends- the battery will continue to die more completely and you will notice more and more signs.
It’s really easy to change a CMOS battery most of the time.
My opinion- don’t over think it. Be aware of static electricity, but not overly worried. Open the case, pop out the old battery, put new one in. It should be a button battery like CR2032 (or it could be a button battery covered in plastic with two wires going to a connector.)
What computer model do you have? Lenovo-H520e?
https://www.makeuseof.com/what-is-a-cmos-battery-and-how-do-you-remove-one/
Hi @JoelA :
thank you so much for the link. :heart:
Great idea. I was already picturing myself scribbling notes on a piece of paper. :wink:
So I won´t necessarily need some antistatic device. That´s good to know.
In the article they say:
Before you proceed to handle PC components, get rid of any static discharge you may have in your body. You can do this by simply touching the metal part of your computer’s cabinet
But the cabinet in painted/varnished in black. Would it get rid of static discharge anyway?
Yes, that´s right. I alsready found out it need a “CR2032”. So it´s 3V, right?
The voltage has to be correct, I guess. Seems crucial.
Many thanks and cheers from Rosika :slightly_smiling_face:
Open your computers case, and have a look, then you’ll be sure.
That’s quite uncommon, I saw such soldered batteries in the late 1990’s, maybe 1999, or early 2000’s.
No, I think you don’t need it.
If you wear a static-charging cloth, such as a synthetic fiber sweater, better get it off before doing the service work :slight_smile:
Anyway, touching a radiator or a tap shortly beofre you reach into the computer - just to be on the safe side- seems to be a good idea.
I only had problem with frequently connected/disconnected cable, with my never or very rarely moved/disconnected USB connection I never-ever had a problem.
Why do you boot always from the USB? It’s not that it should not work -it should- but I don’t really like the idea to have an external drive used like an internal.
That would be a workaround, not a solution :wink:
I’ll do some measuring on my desktop regarding the difference in complete shut down vs. standby/sleep. I bet when shutdown, the power it draws will be below 2W, I expect tha standby power to be between 5…7W, but I’ll measure it.
I always shut down my desktop.
According to my experienc there’s a capacitor on the motherboard in paralell to the battery. The CMOS consumes very-very few energy, so this capacitor easily supplies enough power to the CMOS while you change the battery.
When I purposely want the CMOS to “forget” everything -say becaue of a forgotten BIOS password-, then I need to remove the battery for many minutes, like 10…15 minutes.
That’s quicker of course if I find the jumper labelled “clear CMOS” :slight_smile:
So if you can change the battery fast enough, chances are, the setup will not be forgotten.
Anyway, walk through the setup screens, and take a photo of them for reference, in case you need to redo the BIOS/UEFI setup.
Thanks so much, László, for adding a wealth of useful information. :heart:
I was thinking about that.
But the radiator has paintwork on it, of course. It´s painted in a whitish colour. Wouldn´t that layer of paint act as an insulator then? Or would touchning the radiator still get rid of my bodily static charge :question:
Well, that´s for historical reasons.
The PC came with WIN8 installed (on the internal 500 GB HDD, of course). I didn´t want to get rid of WIN completely back in those days, so I kept it.
I didn´t want to re-partition the internal HDD for dual boot, so I employed that 1 TB HDD for the Linux distro setup.
I never got around to changing this setup situation, as it´s been working well ever since. :wink:
… like me. :wink:
Thanks for letting me know.
I´ve been doing some more research on getting information about the CMOS battery in the meantime and came across this interesting site:
The question asked was
NOTE I need to know about the CMOS battery. not the laptop’s power supply,
My concern was also to procure some information about the state/health of the CMOS battery via the command line.
The page mentioned two methods, and both worked for me. Here are the results;
1.)
rosika@rosika-Lenovo-H520e ~> cat /proc/driver/rtc | grep batt
batt_status	: okay
2.)
rosika@rosika-Lenovo-H520e ~> sensors | grep -i vbat
Vbat:          3.17 V
Wouldn´t the results seem to suggest the CMOS battery is still pretty okay :question: :thinking:
… in addition to the fact that I haven´t encountered any problems with timekeeping.
Thank you so much, László, for your kind help.
Just my opinion.
Of all the suggestions, I think the CMOS battery needing replaced is the most UN-likely.
Why?
Because a PC can be booted without or even with a dead CMOS battery.
The only function of the CMOS battery is to keep the changes a person makes to BIOS which includes date and time. The CMOS battery only uses it’s stored power when the PC is turned off and unplugged.
I found this on the the web;
" Will a computer boot with dead CMOS battery?
Your motherboard and computer will be able to boot just fine even without a CMOS battery present. The only issue is all your BIOS settings will be reset and the time and date will be inaccurate. You will also be unable to save BIOS settings.Nov 2, 2022"
And you may want to read this posting.
Of course it would not hurt replacing the CMOS battery, but it could be a lot work for you taking the back cover of the laptop off and anything else needed to get to the CMOS battery. And of course, putting it all back together again.
Best Regards,
Howard
I think that above situation is the key to solving this.
What is on your Internal HDD today?
Could you reinstall or clone Linux Lite to the HDD, then make it
the boot disk, and boot from there, with the boot controlled by the grub config in the linux on the internal HDD, and with grub written to the internal HDD.
In other words make booting completely independent of the external usb drive.
Then wait for some time and see if the kernel panic still occurs.
If it does not occur, then the issue was with the usb drive or its connections.
You can solve this without a screwdriver.
Do you need Windows anymore? Do you still use Windows? If not, I agree with Neville @nevj.
Install Linux on your internal HDD wiping out Win 8. No dual boot. Your external HDD could be fallback if something went wrong with the install onto the internal HDD. Backup your internal HDD for your primary fallback or at least the EFI partition that points to your external HDD.
Of course as long as a re-boot works with your PC, you do not need to do anything. Just have a plan if the kernel panic gets worse.
Kind Regards,
Howard
That is spot on. @Rosika does not have to do anything urgently. There is time to make a plan, as you advise
Hi again, :wave:
thanks to all of you for your new posts. :heart:
@easyt50 :
I think you´re right in your assessment, Howard.
O.K., I´m ashamed to admit I didn´t know that. That´s good to know.
I see. That might explain why my CMOS battery seems to be in rather good shape after all.
Thanks for the link. I´ll look at the information provided there all the same.
Actually not.
I just kept it for the sake of convenience in case I would run into a situation where I need to use a programme which is available for WIN only.
That kind of scenario never materialized however. I even do my tax declaration on Linux Lite with the help of wine/playonlinux.
Well, it´s rather a fresh boot (after powering down the stuck boot process with the on/off switch. But I know what you mean, Howard.
Actually I´d like to keep it that way for a little while longer, circumstances permitting.
@nevj :
Hmm… I wonder. I´ve been using this setup since 2016 without encountering any hiccups (well, until now that is).
I pretty much doubt booting from the external HDD would be the issue here… :thinking: .
Of course, I may still be wrong.
If everything else fails I may resort to it. Thanks for the suggestion, Neville.
I wrecked my brain trying to remember if any kind of kernel panic happened at any time in the (distant) past.
I seem to recollect that it once happened when trying to boot clonezilla live from a usb stick.
As I said, this was only once in all those years, and it in all probability occured when that shonky usb stick we talked about here was still attached to my system.
That usb-stick turned out to be the culprit; so it was a totally different scenario.
To me it seems the clue to solving the problem would be in finding out the reason why boot works without any kernel panic the second time after it initially failed. :thinking:
I mean: there´s no time delay between the two actions (except for a few seconds) and I didn´t even touch any cable or peripheral device.
So: what might have changed then?
Well, I guess, that´s impossible to find out, especially in view of the fact that there are no logs available.
Thanks so much to all of you for your help :heart:
You said it was getting colder. That affects humidity and I keep getting shocks from everything. Maybe it affects the USB port or cable?
As long as it isn’t a daily occurrence, and you have a backup, I’m not too worried.
Keep warm.
Hi @pdecker :
Quite so. That damn winter… :angry: .
O.K., what you said might of course be a possibility.
Today booting went well again. So I at least try not to worry too much.
Oh dear, That´s easier said than done. :slightly_frowning_face:
Thanks a lot for your opinion.
The temperature changed. It warmed up slightly.
There would be logs in dmesg but you lose that at the next
boot. The log in messages would be preserved.
What you could do to get dmesg would be to not boot Lite again, boot someting else from a usb stick, and look at the /var/log/dmesg in the Lite root filesystem
Hi Neville, :wave:
Actually this thought had entered my mind as well but I dismissed the idea right away as the temperature had not much time to change, perhaps 2 minutes…
… well, a bit longer last time, as I took some screenshots with my smartphone.
Still: you may be right after all, Neville.
messages seem to empty on my system:
ll /var/log/messages
-rw-r--r-- 1 root root 0 Okt 31  2022 /var/log/messages
Nothing to be gained by it, I´m afraid.
I see. That´s a thought. Thanks for bringing it up, Neville. :heart:
I think your system must be using systemd logging instead of
running syslogd.
Hi Neville, :wave:
yes, Linux Lite (being based on Ubuntu) uses systemd.
These are the logs available to me:
ll /var/log | grep -i log
-rw-r--r--  1 root              root             643 Nov 10 16:26 alternatives.log
-rw-r--r--  1 root              root            8,0K Okt 28 17:28 alternatives.log.1
-rw-r--r--  1 root              root             855 Jan 31  2023 alternatives.log.10.gz
-rw-r--r--  1 root              root             715 Jan 16  2023 alternatives.log.11.gz
-rw-r--r--  1 root              root             427 Sep 21 18:10 alternatives.log.2.gz
-rw-r--r--  1 root              root             591 Aug 26 16:38 alternatives.log.3.gz
-rw-r--r--  1 root              root             588 Jul 29 16:33 alternatives.log.4.gz
-rw-r--r--  1 root              root             689 Jun 22 15:19 alternatives.log.5.gz
-rw-r--r--  1 root              root             792 Mai 30 16:02 alternatives.log.6.gz
-rw-r--r--  1 root              root            1018 Apr 21  2023 alternatives.log.7.gz
-rw-r--r--  1 root              root            1,3K Mär 25  2023 alternatives.log.8.gz
-rw-r--r--  1 root              root             749 Feb 24  2023 alternatives.log.9.gz
-rw-r-----  1 syslog            adm              39K Nov 14 13:35 auth.log
-rw-r-----  1 syslog            adm             274K Nov 12 14:14 auth.log.1
-rw-r-----  1 syslog            adm             9,8K Nov  5 14:38 auth.log.2.gz
-rw-r-----  1 syslog            adm              12K Okt 29 12:43 auth.log.3.gz
-rw-r-----  1 syslog            adm              16K Okt 22 14:04 auth.log.4.gz
-rw-------  1 root              root               0 Jan 17  2023 boot.log
-rw-------  1 root              root             11K Jan 17  2023 boot.log.1
-rw-------  1 root              root            6,4K Jan 16  2023 boot.log.2
-rw-r--r--  1 root              root               0 Okt 31  2022 bootstrap.log
-rw-r--r--  1 root              root               0 Okt 31  2022 daemon.log
-rw-r--r--  1 root              root             36K Nov 12 16:16 dpkg.log
-rw-r--r--  1 root              root            309K Okt 28 17:31 dpkg.log.1
-rw-r--r--  1 root              root             48K Jan 31  2023 dpkg.log.10.gz
-rw-r--r--  1 root              root             174 Jan 16  2023 dpkg.log.11.gz
-rw-r--r--  1 root              root             20K Sep 28 15:52 dpkg.log.2.gz
-rw-r--r--  1 root              root            9,7K Aug 26 16:41 dpkg.log.3.gz
-rw-r--r--  1 root              root             13K Jul 31 16:05 dpkg.log.4.gz
-rw-r--r--  1 root              root             14K Jun 22 16:59 dpkg.log.5.gz
-rw-r--r--  1 root              root             15K Mai 30 16:02 dpkg.log.6.gz
-rw-r--r--  1 root              root            9,5K Apr 21  2023 dpkg.log.7.gz
-rw-r--r--  1 root              root             18K Mär 25  2023 dpkg.log.8.gz
-rw-r--r--  1 root              root             23K Feb 24  2023 dpkg.log.9.gz
-rw-r--r--  1 root              root            2,0M Mai 28 14:00 faillog
-rw-r--r--  1 root              root            5,6K Sep 21 18:10 fontconfig.log
-rw-r--r--  1 root              root            1,5K Nov 14 13:23 gpu-manager.log
-rw-r-----  1 syslog            adm             236K Nov 14 13:34 kern.log
-rw-r-----  1 syslog            adm             1,1M Nov 12 14:14 kern.log.1
-rw-r-----  1 syslog            adm             189K Nov  5 14:38 kern.log.2.gz
-rw-r-----  1 syslog            adm             171K Okt 29 12:43 kern.log.3.gz
-rw-r-----  1 syslog            adm             153K Okt 22 14:04 kern.log.4.gz
-rw-rw-r--  1 root              utmp             18M Sep  6 17:26 lastlog
-rw-r--r--  1 root              root             131 Aug  5 18:05 lite-software.log
-rw-r--r--  1 root              root             600 Jan 31  2023 llupdates.log
-rw-r--r--  1 root              root               0 Okt 31  2022 lpr.log
-rw-r-----  1 syslog            adm                0 Okt 31  2022 mail.err
-rw-r-----  1 syslog            adm             1,3K Nov 14 13:25 mail.log
-rw-r-----  1 syslog            adm             2,6K Nov 11 15:56 mail.log.1
-rw-r-----  1 syslog            adm              548 Nov  4 15:56 mail.log.2.gz
-rw-r-----  1 syslog            adm              531 Okt 28 15:56 mail.log.3.gz
-rw-r-----  1 syslog            adm              280 Okt 21 15:50 mail.log.4.gz
-rw-r-----  1 syslog            adm             767K Nov 14 13:38 syslog
-rw-r-----  1 syslog            adm             3,1M Nov 12 14:14 syslog.1
-rw-r-----  1 syslog            adm             451K Nov  5 14:38 syslog.2.gz
-rw-r-----  1 syslog            adm             405K Okt 29 12:43 syslog.3.gz
-rw-r-----  1 syslog            adm             388K Okt 22 14:04 syslog.4.gz
-rw-r--r--  1 root              root               0 Jan 16  2023 ubuntu-advantage.log
-rw-r--r--  1 root              root               0 Aug  1 12:42 ubuntu-advantage-timer.log
-rw-r--r--  1 root              root            1,7K Jul 14 13:10 ubuntu-advantage-timer.log.1
-rw-r--r--  1 root              root             463 Jun 24 12:47 ubuntu-advantage-timer.log.2.gz
-rw-r--r--  1 root              root             598 Mai 31 14:00 ubuntu-advantage-timer.log.3.gz
-rw-r--r--  1 root              root             775 Apr 28  2023 ubuntu-advantage-timer.log.4.gz
-rw-r--r--  1 root              root             750 Mär 31  2023 ubuntu-advantage-timer.log.5.gz
-rw-r--r--  1 root              root             859 Feb 28  2023 ubuntu-advantage-timer.log.6.gz
-rw-r--r--  1 root              root               0 Okt 31  2022 user.log
-rw-r--r--  1 root              root             41K Nov 14 13:25 Xorg.0.log
-rw-r--r--  1 root              root             44K Nov 13 18:48 Xorg.0.log.old
Would one of these be an equivalent to messages?
Thanks and cheers from Rosika :slightly_smiling_face:
Hi @Rosika
The cause of your kernel panic AFAIK is that it cannot mount rootfs.
So I would not expect anything stored…
Thanks, László, :wave:
yes, you are right of course. Thanks for making it clear.
Well, I remember now the more or less exact wording of the message:
Kernel panic - not syncinc … no working init found. Try passing init= option to kernel
You can also see it in the screenshot I provided in my post #15.
What about that then?
What may that mean?
I´m a bit lost here.
