I’ll start with some background. I’ve had a Canon Pixma MX-490 All-In-One Printer/Scanner/Fax device t for several years, and it has served me well, but all good things come to an end, and so it was for my faithful Canon printer. Several days ago, it started to complain that it could not recognize my black ink cartridge, so I ordered a new set of cartridges (one black, and one color). After replacing the cartridges, the printer still produced the same error code. I did some research, and found no solution. I needed to complete an interim report for a local government agency, so time was an issue for me, so I decided to purchase a new printer-scanner.
Since I don’t like HP products (printers in particular - a personal prejudice), and I’ve just had an issue with my Canon printer, I decided to go with another major brand. My first printer was an Epson, and it lived longer than any printer I’ve had since then, so I decided to take a look at the current offerings from Epson. They have several All-in-ones that look a lot like what just went down on me, and Epson’s been pushing their EcoTank printers. I found the Epson ET-2800 printer-scanner on Amazon, for about $200.00(US) plus sales tax. I decided to get it, because the ink supply that comes with it’s supposed to last about two years (an estimate, I’ll see), and I want to get a better quality device than what’s commonly available in the marketplace.
Setting up my new printer was quick and easy on Windows 11. I simply followed the instructions that came with the printer, and the prompts on the roughly 4-inch square LCD screen on the tilt-able front panel. With the printer set up, and connected to my home network, I went to the support page for my printer, and downloaded the user’s manual, and the driver-software installation utility, just to get the utilities for my new scanner. These are probably on the CD that came with my printer, but I don’t have or need a CD reader-writer anymore.
After getting the new printer set up on Windows, and scanning that document (mentioned above) as a PDF, then sending it out, I switched to Garuda. I decided to use the Garuda-setup utility to set everything up (again), much as I did when I installed the OS. This time, I included all the available printer and scanner support items. After completing that process, and restarting the system, my printer was detected almost immediately. I now have a scanner utility to scan documents and images, and I can print from LibreOffice Writer, so I suspect that I can print from any app that supports it.
The more I use Garuda, the better I like it. While I’m not a fan of their flagship release, “Garuda KDE Dr460nized” (I don’t like its looks), I am a fan of both the Garuda-XFCE, and “Garuda Linux KDE lite” flavors. I very much like the familiarity of their XFCE implementation, and I just like the KDE-Plasma desktop environment in general. The thing I like most about their implementation of both of these desktop environments, is the simplicity of their implementations, combined with how well they have integrated the various Garuda utilities they provide. That combination makes for a great looking desktop environment, and surprisingly easy system management.
These are my observations so far. If anything changes, I’ll update this,
Ernie
