Hit a roadblock :
(chroot) livecd /etc # genkernel --mountboot --install all
(chroot) livecd /etc # less /var/log/genkernel.log
-- snip snip --
COMMAND: nice -n10 make -j4 ARCH='x86' AS='x86_64-pc-linux-gnu-as' AR='x86_64-pc-linux-gnu-ar' CC='x86_64-pc-linux-gnu-gcc' LD='x86_64-pc-linux-gnu-ld' NM='x86_64-pc-linux-gnu-nm' OBJCOPY='x86_64-pc-linux-gnu-objcopy' OBJDUMP='x86_64-pc-linux-gnu-objdump' READELF='x86_64-pc-linux-gnu-readelf' STRIP='x86_64-pc-linux-gnu-strip' HOSTAR='x86_64-pc-linux-gnu-ar' HOSTCC='x86_64-pc-linux-gnu-gcc' HOSTCXX='x86_64-pc-linux-gnu-g++' HOSTLD='x86_64-pc-linux-gnu-ld' prepare
SYNC include/config/auto.conf
make[1]: *** No rule to make target 'arch/x86/entry/syscalls/syscall_32.tbl', needed by 'arch/x86/include/generated/uapi/asm/unistd_32.h'. Stop.
make: *** [arch/x86/Makefile:242: archheaders] Error 2
* ERROR: compile_generic() failed to compile the "prepare" target!
* Please consult '/var/log/genkernel.log' for more information and any
* errors that were reported above.
* Report any genkernel bugs to bugs.gentoo.org and
* assign your bug to genkernel@gentoo.org. Please include
* as much information as you can in your bug report; attaching
* '/var/log/genkernel.log' so that your issue can be dealt with effectively.
* Please do *not* report kernel compilation failures as genkernel bugs!
* mount: >> Boot partition state on '/boot' was not changed; Skipping restore boot partition state ...
>>> Ended on: 2023-06-22 03:42:20 (after 0 days 0 hours 00 minutes 15 seconds)
This is the very end of the genkernel.log
Been editing this post for a while now - I think I chose the wrong kernel with eselect :
eselect kernel list
eselect kernel set #
Fingers crossed anywayā¦
