When I use localhost :631 to manage my printers in Debian , I get a list of 2 available printers. One works OK.
The other ( a Brother inkjet printer on an ethernet connection) is listed OK, but when I try to print a test page it says the following
I dont have kerberos turned on , and there is nowhere to enter a username and password?
The same printer in Devuan works fine
I uninstalled and reinstalled CUPS, but it made no difference.
The only thing I can think of is the printer drivers are wrongly installed in Debian ⦠strange because everything used to work? The drivers have to be manually installed from .deb files. Maybe an update corrupted them?
Hello⦠Someone called my name
Actually, Iām no expert, I consider myself a power user of Debian. @nevj, Iāve never seen this error. What system are you on?
I am on Debian 11. It is up to date.
So I have the same CUPS as in your Debian.
Yes that is exactly my error. But it only happens for my Brother inkjet printer when I try to print a testpage. For the other printer, an OKI pageprinter, it behaves normally and I get a test page printed. Both printers are ethernet linked.
I also have Devuan 4. There is no problem with CUPS in Devuan.
I wonder if systemd is involved? That would be the only difference between Debian and Devuan
nevj@trinity:~$ su
Password:
root@trinity:/home/nevj# lpstat -v
device for MFC210C: lpd://192.168.32.98/binary_p1
device for OKI: socket://192.168.32.99
I did apt-get purge cups followed by apt-get install cups. It did not remove the config files. I think I need to wipe the config files and start from scratch
What about to look at some differences between the system it works and doesnāt?
Do you remember how you installed it in Devuan; did you follow the same steps for Debian?
So what tells the same sudo lpstat -v in Devuan?
Is there an obvious difference?
Going forward: groups
(Without sudo, just as the regular user you try to use the printer with)
Check if driver is installed: dpkg -l mfc2*
Is the spool directory there? ls /var/spool/lpd/ -l
See what ācupsā related stuff are installed: dpkg -l cups* dpkg -l fooma*
Iād look at all those output on both systems, where the printer works and where it doesnāt.
If you find an obvious difference, it may be the culprit.
If not, come back, tell what outputs youāve got from the above commands, and do head scratching together.
Edit: another question: do you have a firewall on Debian?
One can use Brother 32 bit drivers in an amd-64 computer/
Additional steps are required
In Debian
1. Install the standard C library for 32-bit applications (eg lib32stdc++6 in De
bian).
2. Check some directories exist
/var/spool/lpd
/usr/lib/cups
/usr/lib/cups/filter
/usr/share/cups/model
3. Install the csh shell
apt-get install csh
4. Install the drivers
dpkg -i --force-all mfc210clpr-1.0.2-1.i386.deb
dpkg -i --force-all cupswrapperMFC210C-1.0.2-3.i386.deb
5. Check drivers installed
dpkg -l | grep Brother
6. Copy brlpdwrapperMFC210C
cp /usr/lib/cups/filter/brlpdwrapperMFC210C /usr/lib64/cups/filter/brlpdwrappe
rMFC210C
7. Copy libraries
cp /usr/lib/libbr* /usr/lib32/
8. Do the CUPS setupd for printer
LPD/LPR Printer
Driver: Brother MFC210C CUPS v1.1
Paper: A4
9. Try a test print page
Both Debian and Devuan have had an inline upgrade since the install. It survived that. This issue in with MFC210C Debian happened later. The OKI printer is not affected, only the MFC210C
There are also scanner drivers⦠they work in Debian. The scanner is a separate device, not managed by CUPS.
I did not set up any firewall in Debian, but when I look with iptables -L there is stuff to do with docker?
I will do as you say and make the tedious comparison of Debian and Devuan.
There is no other way.
Slightly off topic, but a FYI. Brother released a driver install tool a little over a year ago. I had problems installing my MFC-7840W last go around. (never had problems in the past) I discovered the install tool had been released and tried it. It worked for me.
I had always done it by hand before also. For some reason the last time, I couldnāt get the scanner to work. After spending a couple of hours trying to figure out what was wrong I decided to give the installer a shot. It basically automated exactly what I had tried by hand. Still never figured out why I couldnāt get it to work correctly initially.
I did the comparison⦠there were slight differences
groups
Debian
nevj@trinity:~$ groups
nevj adm lp cdrom floppy audio dip video plugdev netdev bluetooth lpadmin scanner docker
Devuan
nevj cdrom floppy sudo audio dip video plugdev netdev lpadmin scanner docker
So I took nevj out of lp in Debian, and added nevj to sudo in Debian.
That made no difference
packages
There was one cups related package present on Devuan , but not in Debian
nevj@trinity:~$ dpkg -l | grep cups
ii cups-pk-helper 0.2.6-1+b1 amd64 PolicyKit helper to configure cups with fine-grained privileges
So I added it to Debian.
That made no difference.
So when all else fails look at the logs
error_log
E [07/Dec/2022:20:42:28 +1100] [Client 10] Returning IPP client-error-not-authorized for Print-Job (ipp://localhost:631/printers/MFC210C) from localhost.
access_log
localhost - - [07/Dec/2022:20:42:28 +1100] "POST /printers/MFC210C HTTP/1.1" 200 383 Print-Job client-error-not-authorized
That says there is some lack of authorization, probably for nevj.
So next I look at /etc/cups/cupsd.conf in Debian and Devuan.
Debian has
DefaultAuthType None
Devuan has
DefaultAuthType Basic
So I change cupsd.conf on Debian to DefaultAuthType Basic
Reboot⦠and it now asks for a name and password when I request a test print for MFC210C.
So is the problem solved? Alas no. It now puts the test print job on the print queue, but it never prints, and eventually disappears from the queue. I suspect this new problem lies with the driver installation.
Iām not an expert, but pretty sure it has to do something with the printer being screwed up at the time. Your Debian was probably active. So yes, just delete every damn printer file and install everything back again. IT WILL WORK!!! Itās LINUX!!!
Best of luck!
