Hey, I thought you were putting it back into the same machine but a new disk?
That is CPU architecture, not disk?
Otherwise messages look OK
I did. Thatās why I did not understand that. Same machine I made the image from, just a previously used (Windows) M.2 disk.
Iāve had internet outages yesterday and today, so havenāt been able to try again. Will attempt again tomorrow.
Thanks,
Then it is a nonsense message. Clonezilla got it wrong.
Well, I gave up on getting CZ to properly put the larger LM installed image onto the smaller M.2 disk.
Today, I installed my new 1 TB M.2 SSD and without doing anything to it first, just booted CZ live and used 2nd option ādisk to diskā since they are the same size. It took about 10 min. WOWā¦fast.
So now I go into BIOS and check, the drive is not there in boot selections, but it is in the NvME storage area. I boot Linux Mint from old SSD and Disks app shows new M.2 by name with exactly same partitions/size as the old SSD.
I chose verbose in CZ and got some messages, most of which I understood. Looking at the image below, CZ appears to be telling me the UUID of new disk has been added and that I will not need to edit grub?
Again with the weird message in yellow about initrd and different system architectureāthis is the same computer used for the image createdājust a new M.2 disk inside said machine.
But I will have to research my motherboard manual for how to get these two drives shown in the BIOS to become options in the boot options.
Despite CZās message about EFI, new LM install does not show up in grub menu. Again, this might have something to do with them being unavailable as boot devices in BIOS.
Any suggestions greatly appreciated.
Well done.
I think I would first try update-grub in the old LM , and see if it can detect the new copy. It should be listed by os-prober, then when you reboot it should be in the grub menu, and you may be able to boot it.
That will not solve why the BIOS is not offering the new disk as a boot option, ⦠it should list all disks⦠you will have to look in the BIOS menu.
It may be that your BIOS can not boot from that disk type?
Late thought:
Check that your new disk has a boot flag on the ā/ā partition. Use gparted to check, an if there is no boot flag on ā/ā give it one.
It is possible that the BIOS will ignore a disk that does not have a boot flag on any partition.
I checked and os-prober revealed the new drive as Linux Mint. I updated grub and it showed up and booted from grub.
The key to getting this set in BIOS was a BIOS option I was unfamiliar with:
Boot/Hard Drive BBS Priorities and it showed the current SATA SSD as #1 and the other M.2 drives were listed as 2 & 3. So I made the new M.2 disk with LM cloned onto it as #1.
Editing fstab was not necessary because it is a clone of the SSD and apparently CZ took care of that (as it had stated after completion).
So I am up and running with a successful CZ clone disk to disk.
Sheila Flanagan
Congratulations.
There are a lot of loose ends⦠especially why could an image not be restored onto a smaller partition.?
I might do an experiment⦠your case is too vital to play with.
and, the boot flag business⦠there was a long discussion between @Daniel_Phillips and myself, ( see Debian Installer Question) and we ended up concluding grub does not need a boot flag, but some Biosās check for it and will not boot if it is absent, especially with legacy boot.
I looked into this in gparted (prior to running os-prober) and here is what both old SSD & new M.2 drives showed:
As you can see in the second image, my original LM on SSD / does not have a boot flag, only efi.
In first image, the M.2 drive with an exact copy of the SSD LM also only has boot flag on efi partition. And I am not on legacy boot, but it is my understanding, at least with LM, grub is on EFI and requires the boot flag.
I would also like to know how to get that dern image on the smaller drive as I feel I am wasting space here by using 1 TB for the OS and apps. My intent was to have a small drive for that and use the 1 TB for /home & backups, both CZ, Timeshift & automated backups.
If you figure it out, I still would like to do it and swap around my current setup.
Thanks,
You could resize the partitions with gparted , and recover some free space⦠backup first.
i think the boot flag can be anywhere, so efi is fine. Grub definitely does not require it. Sometimes the bios requires it, especially the bios in a VM. LM probably puts it there for safety.
I guess my thoughts were to have those items (/home, backups) on a separate drive in case of drive failure, recovery etc. So just making a separate partition for those things on the same M.2 drive was my first path, but again, figuring it is better to have them on a different drive. Or do you think it matters?
Backups, especially CZ , on a separate drive⦠so they protect against disk failure.
TS ⦠not so important where you keep those
/home ⦠yes on the same drive. Those dot files in /home
are vital⦠you need them in the system backup.
Not āhomeā per se, just user directories on a different drive (the way I have been using them on ext HDD) but putting them on a separate partition on same drive might work as long as they are backed up.
Thatās why I wanted the larger drive for CZ images (which can take a bit of space after time) as well as the backups of system, etc. on a separate drive in case of drive failure.
Afterthought, if I partition the new drive, CZ will make an image of all partitions, including that new one for backups and user files?
Thanks,
That will work, and will be faster.
Yes, you dont really want CZ making a backup of TS files.
I think I would use the new disk for system and data, and put TS and CZ files elsewhere.
You dont need to keep more than about 3 CZ
dumps. Remove the older ones regularly.
A backup strategy takes a bit of thought, doesnt it? It is closely tied to the way you partition disks.
Yes, that is why I am still trying to decide the best wayS to cover all bases.
As we have seen, CZ is great for image backups. Timeshift is good for system backups to roll back on same system. But I also need to have an automated backup (Resilio if I can figure it outābeen a long time since I used it) for user files (then backing those up to home server) since I am getting rid of the cloud in 2 weeks.
My (non automatic) backup for user data files is to rsync them to an external usb disk. I can run that as often as I want, while I am working. I suppose I could put it in cron or anacron and automate it.
Thatās what I am researching next. Have never used cronjobs, but know that I could somehow automate the rsync command for the user directories, whether on another partition or another disk. Just havenāt felt comfortable yet with all the flag options for rsync but I will take it step by step and figure it out.
Thanks,
Thanks so much @Rosika . I did not know there was a GUI for rsync. That will help tremendously with my trepidation of try and fail.
You“re welcome, Sheila.
On DEB-based systems you can install it with
sudo apt-get install grsync .
Here“s its homepage: OPByte: Grsync rsync GUI interface frontend for Linux, Windows and Mac OS X
Cheers from Rosika ![]()
Thank you.
I didnāt know of a GUI for rsync either
