What does "SMART ATA Error Log Structure error: invalid SMART checksum." mean?
Hello friends
I have a situation about the SSD reported at:
I did do a research in the web and is suggested work with the smartctl command and GSMartControl GUI
First the SSD partitions for a better understanding
/dev/sda1
/dev/sda2
As follows the reports:
sudo smartctl -H /dev/sda1
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-6.5.0-35-generic] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
sudo smartctl -H /dev/sda2
So far all seem fine
sudo smartctl -a /dev/sda1
Device Model:     WD Blue SA510 2.5 1000GB
Serial Number:    22196N807187
LU WWN Device Id: 5 001b44 8b08f5266
Firmware Version: 52008100
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
TRIM Command:     Available, deterministic
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-4, ACS-2 T13/2015-D revision 3
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sun Jun  9 10:45:21 2024 -05
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
					Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		(    0) seconds.
capabilities: 			 (0x71) SMART execute Offline immediate.
					No Auto Offline data collection support.
					Suspend Offline collection upon new
					command.
					No Offline surface scan supported.
					Self-test supported.
					Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   1) minutes.
Extended self-test routine
recommended polling time: 	 (  10) minutes.
Conveyance self-test routine
SMART Attributes Data Structure revision number: 0
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  5 Reallocated_Sector_Ct   0x0032   100   100   010    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       2
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       1057
165 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       98173724
166 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
167 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       17
168 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       1
169 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       236
170 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
171 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
172 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
173 Unknown_Attribute       0x0032   100   100   005    Old_age   Always       -       0
174 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       742
184 End-to-End_Error        0x0032   100   100   097    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
194 Temperature_Celsius     0x0022   100   100   014    Old_age   Always       -       32 (Min/Max 17/39)
199 UDMA_CRC_Error_Count    0x0032   100   100   000    Old_age   Always       -       0
230 Unknown_SSD_Attribute   0x0032   100   100   000    Old_age   Always       -       1524713390435
232 Available_Reservd_Space 0x0033   100   100   004    Pre-fail  Always       -       94
233 Media_Wearout_Indicator 0x0032   100   100   000    Old_age   Always       -       0
234 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       16429
241 Total_LBAs_Written      0x0030   253   253   000    Old_age   Offline      -       530
242 Total_LBAs_Read         0x0030   253   253   000    Old_age   Offline      -       382
244 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
Warning! SMART ATA Error Log Structure error: invalid SMART checksum.
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%         2         -
# 2  Short offline       Completed without error       00%         0         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
sudo smartctl -a /dev/sda2
Local Time is:    Sun Jun  9 10:47:52 2024 -05
					was never started.
					been run.
					command.
					power-saving mode.
165 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       98632477
194 Temperature_Celsius     0x0022   100   100   014    Old_age   Always       -       33 (Min/Max 17/39)
234 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       16467
No Errors Logged
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
sudo smartctl -x /dev/sda1
Local Time is:    Sun Jun  9 10:49:42 2024 -05
AAM feature is:   Unavailable
APM level is:     254 (maximum performance)
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Unavailable
					was never started.
					been run.
					command.
					power-saving mode.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  5 Reallocated_Sector_Ct   -O--CK   100   100   010    -    0
  9 Power_On_Hours          -O--CK   100   100   000    -    2
 12 Power_Cycle_Count       -O--CK   100   100   000    -    1057
165 Unknown_Attribute       -O--CK   100   100   000    -    99025695
166 Unknown_Attribute       -O--CK   100   100   000    -    0
167 Unknown_Attribute       -O--CK   100   100   000    -    17
168 Unknown_Attribute       -O--CK   100   100   000    -    1
169 Unknown_Attribute       -O--CK   100   100   000    -    236
170 Unknown_Attribute       -O--CK   100   100   000    -    0
171 Unknown_Attribute       -O--CK   100   100   000    -    0
172 Unknown_Attribute       -O--CK   100   100   000    -    0
173 Unknown_Attribute       -O--CK   100   100   005    -    0
174 Unknown_Attribute       -O--CK   100   100   000    -    742
184 End-to-End_Error        -O--CK   100   100   097    -    0
187 Reported_Uncorrect      -O--CK   100   100   000    -    0
188 Command_Timeout         -O--CK   100   100   000    -    0
194 Temperature_Celsius     -O---K   100   100   014    -    34 (Min/Max 17/39)
199 UDMA_CRC_Error_Count    -O--CK   100   100   000    -    0
230 Unknown_SSD_Attribute   -O--CK   100   100   000    -    1524713390435
232 Available_Reservd_Space PO--CK   100   100   004    -    94
233 Media_Wearout_Indicator -O--CK   100   100   000    -    0
234 Unknown_Attribute       -O--CK   100   100   000    -    16499
241 Total_LBAs_Written      ----CK   253   253   000    -    530
242 Total_LBAs_Read         ----CK   253   253   000    -    382
244 Unknown_Attribute       -O--CK   100   100   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      1  Comprehensive SMART error log
0x03       GPL     R/O     16  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa0-0xa1  GPL,SL  VS       1  Device vendor specific log
0xa2       GPL,SL  VS       2  Device vendor specific log
0xa3-0xa7  GPL,SL  VS       1  Device vendor specific log
0xde       GPL,SL  VS       1  Device vendor specific log
Warning! SMART Extended Comprehensive Error Log Structure error: invalid SMART checksum.
SMART Extended Comprehensive Error Log Version: 1 (16 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
SCT Commands not supported
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (empty) ==
0x05  =====  =               =  ===  == Temperature Statistics (empty) ==
0x07  =====  =               =  ===  == Solid State Device Statistics (empty) ==
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0009  2            0  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            5  Device-to-host register FISes sent due to a COMRESET
0x000f  2            0  R_ERR response for host-to-device data FIS, CRC
0x0013  2            0  R_ERR response for host-to-device non-data FIS, non-CRC
sudo smartctl -x /dev/sda2
Local Time is:    Sun Jun  9 10:51:02 2024 -05
					was never started.
					been run.
					command.
					power-saving mode.
165 Unknown_Attribute       -O--CK   100   100   000    -    99287840
230 Unknown_SSD_Attribute   -O--CK   100   100   000    -    2199023256064
234 Unknown_Attribute       -O--CK   100   100   000    -    16521
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
                                ||__ D supports DSN
Sorry for the long outputs
I am not an expert about this data report, so I am providing detailed information for you. According with the long output, Should I assume the SSD is passing away? So far my main concern is the following:
No Errors Logged
No Errors Logged
Note: Pls, if you find some important point in the result let me know
Furthermore was executed the GSMartControl tool, with Extended Self-test, as follows:
Once completed, in the Error Log tab appears as follows:
Again
Complete error log
No Errors Logged
If is pressed the View Output button the report is as follows:
Local Time is:    Sun Jun  9 11:09:28 2024 -05
					was never started.
					been run.
					command.
					power-saving mode.
  9 Power_On_Hours          -O--CK   100   100   000    -    4
165 Unknown_Attribute       -O--CK   100   100   000    -    100729639
194 Temperature_Celsius     -O---K   100   100   014    -    31 (Min/Max 17/39)
230 Unknown_SSD_Attribute   -O--CK   100   100   000    -    2203318223361
234 Unknown_Attribute       -O--CK   100   100   000    -    16654
241 Total_LBAs_Written      ----CK   253   253   000    -    531
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
# 1  Extended offline    Completed without error       00%         3         -
# 2  Extended offline    Completed without error       00%         2         -
# 3  Short offline       Completed without error       00%         0         -
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
                                ||__ D supports DSN
Note: remember in the link of the other post, through the SMART DATA & Self-Tests... tool, about the id with 234 (Uncorrectable ECC Count) its value is always increasing, so far with 16xxx sectors, so from that value is reported here the
Again, is my SSD passing away? I am not sure what to do, in these days I am going to go to the hardware provider, to apply the warranty if is necessary, so I am want be very sure the information he is going to give me matches with your answer(s).
Thanks for your understanding
You only need to run smartctl on the raw device, not the partitions.
i.e. /dev/sda - not /dev/sda1, 2, 3 et cetera (sda1, sda2 etc are partitions).
So - you only need to run it once :
Pop!_OS :
╭─x@fenrix ~
╰─➤  lsblk
NAME            MAJ:MIN RM   SIZE RO TYPE  MOUNTPOINTS
loop0             7:0    0  96.1M  1 loop  /snap/cool-retro-term/150
loop1             7:1    0  55.7M  1 loop  /snap/core18/2812
loop2             7:2    0  55.7M  1 loop  /snap/core18/2823
loop3             7:3    0  74.2M  1 loop  /snap/core22/1122
loop4             7:4    0 284.6M  1 loop  /snap/gzdoom/121
loop6             7:6    0  38.7M  1 loop  /snap/snapd/21465
loop7             7:7    0  74.2M  1 loop  /snap/core22/1380
loop8             7:8    0  38.8M  1 loop  /snap/snapd/21759
zram0           251:0    0  13.6G  0 disk  [SWAP]
nvme0n1         259:0    0 931.5G  0 disk
├─nvme0n1p1     259:1    0  1022M  0 part  /boot/efi
├─nvme0n1p2     259:2    0     4G  0 part  /recovery
├─nvme0n1p3     259:3    0 922.5G  0 part
│ └─cryptdata   252:0    0 922.5G  0 crypt
│   └─data-root 252:1    0 922.5G  0 lvm   /
└─nvme0n1p4     259:4    0     4G  0 part
  └─cryptswap   252:2    0     4G  0 crypt [SWAP]
In my case - I’m only interested in nvme0n1 above :
╭─x@fenrix ~
╰─➤  sudo smartctl -H /dev/nvme0n1
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-6.6.6-76060606-generic] (local build)
=== START OF SMART DATA SECTION ===
On Red Hat systems - SSD are abstracted as /dev/sda, /dev/sdb et cetera, my RHEL 8 system :
╭─x@fuglpige ~
╰─➤  sudo lsblk
loop0           7:0    0 106.3M  1 loop /var/lib/snapd/snap/motioneye/294
loop1           7:1    0  49.9M  1 loop /var/lib/snapd/snap/snapd/18596
loop2           7:2    0  55.6M  1 loop /var/lib/snapd/snap/core18/2721
sda             8:0    0   477G  0 disk
├─sda1          8:1    0  1000M  0 part /boot/efi
├─sda2          8:2    0  1000M  0 part /boot
└─sda3          8:3    0   475G  0 part
  ├─rhel-root 253:0    0 460.1G  0 lvm  /
  └─rhel-swap 253:1    0  14.9G  0 lvm  [SWAP]
So I only need to run smartctl against sda (/dev/sda) :
╭─x@fuglpige ~
╰─➤  sudo smartctl -H /dev/sda
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-4.18.0-513.18.1.el8_9.x86_64] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
Hello Dan
Thanks for that point, I didn’t know. To be honest I took the approach shared because in that way is indicated in the tutorials, based on partitions. It is the reason about why I used the the Disks GUI to know the partitions.
Let me execute the same command with your suggested approach to share the results later.
Just in case the GSmartControl GUI used, see the first figure shared about that and see the left top - there appears Device: /dev/sda, it is not based on partitions, so I am assuming the results shared later about that tool is valid according your suggestion. If you can check that output, pls share your thoughts
Ok Here we go
lsblk
loop0    7:0    0     4K  1 loop /snap/bare/5
loop1    7:1    0    14M  1 loop /snap/chromium-ffmpeg/37
loop2    7:2    0  13.9M  1 loop /snap/chromium-ffmpeg/41
loop3    7:3    0  55.7M  1 loop /snap/core18/2812
loop4    7:4    0  55.7M  1 loop /snap/core18/2823
loop5    7:5    0  63.9M  1 loop /snap/core20/2264
loop6    7:6    0  63.9M  1 loop /snap/core20/2318
loop7    7:7    0  74.2M  1 loop /snap/core22/1122
loop8    7:8    0  74.2M  1 loop /snap/core22/1380
loop9    7:9    0 118.9M  1 loop /snap/drawio/214
loop10   7:10   0 119.1M  1 loop /snap/drawio/217
loop11   7:11   0 270.7M  1 loop /snap/firefox/4259
loop12   7:12   0 270.7M  1 loop /snap/firefox/4336
loop13   7:13   0 164.8M  1 loop /snap/gnome-3-28-1804/194
loop14   7:14   0 164.8M  1 loop /snap/gnome-3-28-1804/198
loop15   7:15   0 349.7M  1 loop /snap/gnome-3-38-2004/140
loop16   7:16   0 349.7M  1 loop /snap/gnome-3-38-2004/143
loop17   7:17   0 504.2M  1 loop /snap/gnome-42-2204/172
loop18   7:18   0 505.1M  1 loop /snap/gnome-42-2204/176
loop19   7:19   0  91.7M  1 loop /snap/gtk-common-themes/1535
loop20   7:20   0  12.9M  1 loop /snap/snap-store/1113
loop21   7:21   0  12.3M  1 loop /snap/snap-store/959
loop22   7:22   0  38.7M  1 loop /snap/snapd/21465
loop23   7:23   0  38.8M  1 loop /snap/snapd/21759
loop24   7:24   0   476K  1 loop /snap/snapd-desktop-integration/157
loop25   7:25   0   452K  1 loop /snap/snapd-desktop-integration/83
loop26   7:26   0 321.1M  1 loop /snap/vlc/3721
loop27   7:27   0 321.1M  1 loop /snap/vlc/3777
sda      8:0    0 931.5G  0 disk
├─sda1   8:1    0   512M  0 part /boot/efi
└─sda2   8:2    0   931G  0 part /var/snap/firefox/common/host-hunspell
sr0     11:0    1  1024M  0 rom
So you was right about the abstract part:
Wondered why appears firefox there …
Therefore
Because it’s installed as a snap…
Interesting, I assumed it should be installed within a common directory.
Some thoughts about the shared reports?
That is not where it is, that is a mount point for the loop mount
