Which frontend for KVM?!
Hey,
I was previously running Pop!_OS (22.04) on my desktop machine, and used Oracle Virtualbox with a bunch of VMs (mostly other Linux distros - but also a Windows server and FreeBSD)…
Now have a fresh install of Ubuntu 24.04 (Gnome 46)…
I don’t want to go the VirtualBox route this time around. I’d like something closer to my kernel - i.e. more “native”…
I see there’s “virt-manager” and also Gnome-Boxes.. What other ones? Looking for recommendations… I don’t want to start off cold with CLI deployment of guests…
I would like to get my head around CLI management of KVM - but - would prefer a GUI frontend to kick-off a few VMs to get started… Probably mostly Red Hat (VMs) as that’s about 90% of my job (Red Hat Linux 8 and 9)…
– edit –
CRAP! Just checked my CPU and it’s not currently supporting KVM…
I know why that is too - had to reset my UEFI / BIOS couple weeks back to change boot order / detection - and this CRAP BIOS for this pretty crap MOBO - calls AMD Virtualization “svm” (I think?). I’ll never get another MSI mobo ever again - garbage BIOS - feels like child’s toy - and you pretty much can’t drive the BIOS without a f–king mouse - that’s a joke! That’s not “pro”!
Anyway - the CPU flags set when I cat /proc/cpuinfo - shows “smv_lock” and :
╭─x@titanii ~/Videos/Movies/1982-Koyaanisqatsi
╰─➤  sudo kvm-ok        127 ↵
INFO: Your CPU does not support KVM extensions
KVM acceleration can NOT be used
Pezzo di merda!
Next time I get a mobo - I reckon I’ll go back to Asus… What was wrong with a text based BIOS interface?
– edit 2 –
Shutdown…
Bios :
OC Explore Mode (Expert) > CPU Features > Enable SVM Mode
The useless sods have buried it three layers deep - and just WTF does amdv / svm have to do with fecking OverClocking? BUGGER ALL!
Anyway - my machine now passes “muster” :
╭─x@titanii ~/MPZ/ENO-Brian
╰─➤  sudo kvm-ok
INFO: /dev/kvm exists
KVM acceleration can be used
I think virt-manager for you.
virt-manager is the graphic interface… you can also use virsh at CLI on the same VM.
I have a collection of URL’s
https://ckirbach.wordpress.com/2017/07/25/how-to-add-a-physical-device-or-physical-partition-as-virtual-hard-disk-under-virt-manager/
https://www.debugpoint.com/share-folder-virt-manager/
https://blog.sergeantbiggs.net/posts/file-sharing-with-qemu-and-virt-manager/
https://shallowsky.com/blog/linux/virt-manager.html
https://wiki.libvirt.org/VirtualNetworking.html
https://serverfault.com/questions/235310/mounting-to-external-nfs-from-a-kvm-vm
https://serverfault.com/questions/482146/how-to-mount-an-nfs-share-in-a-vm-guest
https://shallowsky.com/blog/linux/qemu-shared-folder.html
https://www.linux.com/training-tutorials/what-ip-masquerading-and-when-it-use/
https://jamielinux.com/docs/libvirt-networking-handbook/
https://wiki.archlinux.org/title/libvirt
https://computingforgeeks.com/virsh-commands-cheatsheet/
https://www.redhat.com/sysadmin/virsh-subcommands
and there are some FOSS topics… search for virt-manager.
Unless you want to use raw qemu ?
Boxes is more user-friendly but less powerful.
Can I add 2 documents that came via @Rosika
https://github.com/nevillejackson/Documents/blob/main/kgw_QEMU.pdf
https://github.com/nevillejackson/Documents/blob/main/kgw_virsh_ubuntuusers.pdf
Last time I played with vms I used Qemu. It worked really well.
There are a lot of options to learn
I had one try… it worked but had display issues. I did not persist.
If I can’t try a new distro in Boxes, I won’t try it. Boxes is all I need.
Yes, Boxes is fine for trying a distro.
If you want to use a VM permanently, and maybe login to it remotely and share files, or connect to hardware, I think you need virt-manager.
There is another option called distrobox, which is more like a container than a VM.
@daniel.m.tripp You might take a look at LXD.
You can run VMs and containers. I’ve used Boxes a bit and had pretty good luck too.
Another Ubuntu thing is MicroCloud. Maybe that’s the one that will do both VMs and containers. It uses LXD as a backend.
One thing I like about both of these is they install via Snap. That should mean an easy install and a clean uninstall that doesn’t affect anything else after evaluation.
Yeah - reckon I’ll go with that option VS Boxes…
There’s a port of virt-manager to MacOs too… So I can install / configure VMs from my Linux desktop - and manage / tweak from MacOs too…
I can remember using virt-manager some 10 or so years ago when I got fed up of VirtualBox… bit more of a learning curve… But I don’t need to know VirtualBox for my job… I do need to know a bit more about KVM, virt-manager, and especially “virsh” for my job… I can do all this on my home system…
Red Hat have a management UI for their enterprise KVM solution… I looked at it once - looks/feels more like VMware than virt-manager…
I do also need to know about VMware / ESX for my job - don’t really have the infrastructure for that - and - Broadcom (talk about the shittiest of the enshittifiers) have pretty much destroyed that ecosystem for home lab users…
Not really interested in LXD - I’ve looked at that before - before “docker” became all the rage… But thanks for the suggestion…
So - I’ll probably go for virt-manager to get started - and then get my head around virsh and qemu…
I’m already kinda/sorta using QEMU via the UTM app on MacOS - but that also takes all the heavy lifting from you…
Red Hat were the original developers of virt-manager.
Broadcom has reinstated the free version of ESXi. We still run the licensed version that never expires. Can’t get any updates without $$$. For a lab, I purchased a Dell precision workstation (with supported CPU) on eBay for about $300. Running ESXi 8u03, Dell specific. Have 8 virtual machines on it but only run 3 or 4 at a time. Use Veeam to backup images to TrueNAS running on another re-purposed workstation. Turn on, backup, and turn off.
I am also a fan of virt-manager. You can also install cockpit to configure your VMs through your browser, etc.
OK - just done my first VM (Ubuntu 24.04.3 desktop) in KVM using virt-manager (I’ve done it before - but quite a few years ago now)…
But - I’m wanting to do bridged adaptor - which is reasonably straightforward with VirtualBox (but even so - something so simple still stumps casual new users - like the ephemeral floods of Kali users trying to get their Kali VM on their LAN) - seems not so simple with KVM…
Hmmm - I might persevere with NAT in KVM / virt-manager for the time being…
Trying out an install of RHEL 9 now…
Just tried emulating aarch64 and an emulated Pi3 - and it complained about ACPI - so I switched back to x86_64… still got a fair bit to learn about QEMU I guess… I’ve emulated x86, Sparc and PPC in QEMU in UTM on my M1 MacBooks (i.e. on aarch64 MacOS).
Are you usung qemu directly for that, or via virsh?
In “virt-manager”… So - is that virsh sitting behind it? So not directly… But in UTM on MacOS - it’s seems better integrated with QEMU than virt-manager…
Here’s what I LOVE about virt-manager - e.g. I’m running RHEL9 with Gnome 40, and, in a terminal - the X select buffer works inside, and outside… So - I can paste from my desktop machine, into a terminal window in a Linux guest… virtualbox can’t do that (not in all my testing anyway). Or I can select a string of text in my guest’s terminal window - and - paste into a browser on my desktop machine…
The other thing I like about virt-manager - you can opt to see the xml it will generate… that’s a pretty neat learning tool!
I have akways had to install spice-vdagent in the guest to get copy/paste working.
Most linuxes have spice-vdagent , but BSD does not.
Yeah, you can even modify the xml.
You can do NFS mounts across the NAT connection. You dont need a bridge for that.
Yeah - already discovered that for myself…
But - here’s the deal with RHEL9… by default it doesn’t have an NFS client installed (for that matter neither does Ubuntu)… but getting one installed in RHEL proved “thorny”… I kept scp’ing RPM files from the DVD - and finding yet more dependancies… Gave up… setup subscription manager and licensed it with my developer license and was able to install nfs-utils and dependancies from RHN CDN repos (only works if legitimately subscribed)… i.e. RHEL9 doesn’t connect to any repos (I know a way to make it use the DVD ISO image as a software repo - but - getting 9 GB of ISO image onto a small VM not always feasible - and not via NFS as I don’t have a client installed! Vicious circle…)
The thing that bridge networked will get me - is ability to SSH to a KVM VM from outside of my hypervisor machine… I guess I could setup ProxyJump SSH config but that’s too much messing around…
One thing I did notice - on this Ubuntu desktop machine running KVM with virt-manager installed - I didn’t even have bridge-manager insalled… but I’m still no nearer to getting bridged network adapter working in kvm / virsh… it’s not a biggie… But I’d kinda like the luxury of being able to directly SSH to a VM hosted on another machine - and - managing stuff like ResilioSync client remotely - probably not possible or viable with NAT (e.g. I don’t think setting up a static route is the answer either!). I’ve setup my main LAN with a /14 CIDR… I’d rather just use something in that vast space…
Also - one of the dumbest pages I’ve come across in a while :
i.e. you can install a gnome extension if you know the UUID - but - HOW DO YOU FIND THAT OUT??? Dumb!
– edit –
dumb as in it doesn’t even have a link to page where you can get the UUID from - what’s the point of the page?
They might have chosen another acronym. UUID has other meanings in relation to disk partitions.
That seems like a perfectly reasonable thing to do. If you can’t get a bridged network running, you could use Tailscale. It seems like the long way around to setup a VPN to SSH to a VM running on your network, but it would work.
I know I’m not as schooled as you guys are but ssh is how I am building LFS. Most times I just use the host machine that has my VirtualBox LFS on, but I have also used ssh from my Gentoo and my other Windows machine. With the help of a script from copilot, I finally got mesa compiled, via ssh!!!
That is like the way people build headless servers
