As usual thanks for the replies
The disable fast boot didnât work but
I have the following advance
At the BIOS for the âBootâ Menu exists the following:
Boot
Boot Configuration
Fast Boot [Enabled]
Launch CSM [Disabled]
Boot option Priorities
<Empty here should appear the SSD>
Add New Boot option
Delete Boot option
About âEmpty here should appear the SSDâ even when the USB is plugged, the boot event does not happen, always the BIOS is loaded instead. But later is possible detect both devices, the USB and SSD
For the âAdd New Boot optionâ item appears:
Add New Boot Option
Add boot option
Path for boot option
Boot option File Path (generated according with "Path for boot option", otherwise empty)
Create (is mandatory have defined "Add boot option" and "Path for boot option",
otherwise appears the following Warning message as:
"Please set Boot Option Name and File Path")
Therefore working with the 2 first options
- For the âAdd boot optionâ must be written a custom name such as either âUSBâ or âWindows10â according the case
- For the âPath for boot optionâ appears detected the SSD and USB respectively with the following set of options according the navigation
Note: The â*â is only used to improve the hierarchy
PCI(1D|0)\PCI(0|0)\DevicePath(Type 3, SubType 17)HD(Part1, Sig<possible-uuid>) <--- It is the SSD
* <EFI>
* <..> (to return)
* <Microsoft>
* <..> (to return)
* <Boot>
* <..> (to return)
* ... more options ...
* <en-GB>
* <en-US>
* <es-ES>
* <es-MX>
* <Fonts>
* <qps-ploc>
* <..> (to return)
* <Resources>
* <..> (to return)
* <en-US>
* <es-ES>
* <fr-FR>
* SecureBootRecovery.efi
* memtest.efi
* bootmgr.efi
* bootmgfw.efi
* <Recovery>
* <..> (to return)
* <Boot>
* <..> (to return)
* bootx64.efi
* <System Volume Information>
<..> (to return)
PCI(14|0)\USB(15,0)\HD(Part2,Sig23919B4D) <--- It is the USB
* <grub>
* <arm64-efi>
* <..> (to return)
* <distro>
* <..> (to return)
* <fonts>
* <..> (to return)
* <i386-efi>
* <..> (to return)
* <i386-pc>
* <..> (to return)
* <mips64el-efi>
* <..> (to return)
* <themes>
* <..> (to return)
* <ventoy>
* <..> (to return)
* <x86_64-efi>
* <ventoy>
* <..> (to return)
* <7z>
* <..> (to return)
* <64>
* <..> (to return)
* <32>
* <..> (to return)
* <imdisk>
* <..> (to return)
* <64>
* <..> (to return)
* <32>
* <..> (to return)
* iso9660_ia32.efi
* ventoy_ia32.efi
* ventoy_x64.efi
* iso9660_x64.efi
* vtoyutil_aa64.efi
* udf_aa64.efi
* udf_x64.efi
* vtoyutil_x64.efi
* ventoy_aa64.efi
* vtoyutil_ia32.efi
* iso9660_aa64.efi
* udf_ia32.efi
* <EFI>
* <..> (to return)
* <BOOT>
* grubia32_real.efi
* MokManager.efi
* grubx64_real.efi
* grub.efi
* BOOTIA32.EFI
* mmia32.efi
* BOOTMIPS.EFI
* BOOTAA64.EFI
* BOOTX64.EFI
* grubia32.efi
* <tool>
* <..> (to return)
* <..> (to return)
Therefore for each device
- What is the correct .efi file?
It is for a ASUS UX501VW-DS71T (2016) in perfect conditions about hardware (500gb SSD, 16gb RAM)
Note:
- 1 or 2 days ago before of the problem an update of Windows 10 Home was accomplished in the same way done throughout the years
Perhaps it was a coincidence or not
Goal(s)
- Boot Windows 10 from the SSD
- Boot from Ventoy to load the iso file of Ubuntu and mount in peace the SSD
Thank You
