CentOS and WiFi with Ralink RT5370
I have an HP Stream laptop which originally ran Windows 10. It just didn’t have the storage space to run Windows 10 updates so I installed Centos 7. This was installed from 7.8 media and updated to 7.9.
The onboard wifi card (a Broadcom BCM43142) doesn’t work due to Broadcom’s licensing policy. I managed to find a compatible USB dongle, Ralink RT5370, which worked OK for a while but now it is slow and constantly dropping out. This makes it extremely difficult to get anything done which requires a network connection. My system information is as follows:
4 colin@stream> uname -a
Linux stream 3.10.0-1160.11.1.el7.x86_64 #1 SMP Fri Dec 18 16:34:56 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
5 colin@stream> cat /etc/centos-release
CentOS Linux release 7.9.2009 (Core)
6 colin@stream>
1 colin@stream> lspci
00:00.0 Host bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SoC Transaction Register (rev 21)
00:02.0 VGA compatible controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics Controller (rev 21)
00:0b.0 Signal processing controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Power Management Controller (rev 21)
00:14.0 USB controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series USB xHCI Controller (rev 21)
00:1a.0 Encryption controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series Trusted Execution Engine (rev 21)
00:1b.0 Audio device: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series High Definition Audio Controller (rev 21)
00:1c.0 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Express Port #1 (rev 21)
00:1c.3 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCI Express Port #4 (rev 21)
00:1f.0 ISA bridge: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series PCU (rev 21)
00:1f.3 SMBus: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx SMBus Controller (rev 21)
01:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
02:00.0 Network controller: Broadcom Inc. and subsidiaries BCM43142 802.11b/g/n (rev 01)
2 colin@stream> lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 0a5c:216d Broadcom Corp. BCM43142A0 Bluetooth 4.0
Bus 001 Device 004: ID 0bda:57c4 Realtek Semiconductor Corp.
Bus 001 Device 003: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Bus 001 Device 002: ID 045e:07fd Microsoft Corp. Nano Transceiver 1.1
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
3 colin@stream>
3 colin@stream> lsmod | grep rt2800
rt2800usb              31203  0
rt2x00usb              20778  1 rt2800usb
rt2800lib             106640  1 rt2800usb
crc_ccitt              12707  1 rt2800lib
rt2x00lib              70005  3 rt2x00usb,rt2800lib,rt2800usb
mac80211              770617  3 rt2x00lib,rt2x00usb,rt2800lib
4 colin@stream>
When I try to use yum to install software, I see errors as shown below and the process generally fails:
http://mirror.sov.uk.goscomb.net/centos/7.9.2009/extras/x86_64/repodata/cd5c5a43f22077a43a0af22f1999a97312975ce0abbf9c09f6120055a212c3fa-primary.sqlite.bz2: [Errno 12] Timeout on http://mirror.sov.uk.goscomb.net/centos/7.9.2009/extras/x86_64/repodata/cd5c5a43f22077a43a0af22f1999a97312975ce0abbf9c09f6120055a212c3fa-primary.sqlite.bz2: (28, 'Operation too slow. Less than 1000 bytes/sec transferred the last 30 seconds')
epel/x86_64/updateinfo         FAILED                                                             ]  12 kB/s | 1.2 MB  00:29:28 ETA
http://www.fedora.is/fedora/epel/7/x86_64/repodata/a50341a580e9935c68088e2e7caf182b4f96bd118e1fb4513aa4f47df72ff995-updateinfo.xml.bz2: [Errno 12] Timeout on http://www.fedora.is/fedora/epel/7/x86_64/repodata/a50341a580e9935c68088e2e7caf182b4f96bd118e1fb4513aa4f47df72ff995-updateinfo.xml.bz2: (28, 'Resolving timed out after 30546 milliseconds')
Trying other mirror.
I have tried disabling the “fastestmirror” plugin to no avail and have the appropriate driver (I think) but can’t compile it until I can get gcc installed via yum. I believe the rt2800usb kernel module should work but it doesn’t seem to be optimal. So, I guess I have a few questions for the experts (which I am not):
  • Is there any other information you might need to help debug this problem?
  • Would an Ubuntu/mint install work better with the RT5370?
  • Is there an “install drivers for dummies” guide you could point me towards?
  • If all else fails, can anyone recommend a different brand/chipset of USB wifi dongle that will work “out of the box” in Centos 7?
I’m really at a loss here, so any advice would be gratefully received.
Regards,
Colin Brett
https://www.cyberciti.biz/faq/howto-display-list-of-modules-or-device-drivers-in-the-linux-kernel/
It would be nice to get a list of all drivers and then get as much details on the driver you need for the USB dongle. If more than one is installed, then give details on all of those related to the device you are currently using. Please also put each distinct set of information in their own code formatting box, so we don’t have to scroll for an hour through a single one.
https://tldp.org/HOWTO/Hardware-HOWTO/
https://linux-laptop.net/
https://www.cyberciti.biz/tips/linux-usb-wireless-compatibility-adapter-list.html (2010)
Ubuntu Linux Compatible WiFi USB Adapters - Will Haley
RPi USB Wi-Fi Adapters - eLinux.org
https://www.addictivetips.com/ubuntu-linux-tips/usb-wifi-adapter-linux/
Linux & Wireless LANs
I would recommend using an Ethernet connection as long as you need to download something or do something else on the internet. When you are done, you can try to resolve the WiFi issue, as described above.
Welcome @colinabrett you are now a FOSSer :smiley:
I would advise to do a search on “Ralink” where you would have found…
https://www.thinkpenguin.com/gnu-linux/penguin-wireless-n-usb-adapter-gnu-linux-tpe-n150usb
Cent OS 7 and 8 are listed - Saves a lot of hassle :yum:
