Hi, I have a similar problem. I have a LenovaG580 with Ubuntu 19.10 installed. WiFi was operational. Now I upgraded it to 20.04LTS there is no WiFi at all. When check the settings-network only wired option is seen. How can I tell 20.04 about the WiFi availability of the notebook?
Is the Ethernet cable plugged in?
No! I want WiFi only
Did you re-install 3rd party drivers for the Wi-Fi card?
Hi,
Can your system see the wifi adapter? Check the result of this command:
sudo lshw -C network
If the wifi adapter is recognized, then check if it is being soft or hard blocked:
rfkill
If it is not blocked at all and you have the Ethernet connection, try o see if there are additional drivers available for your wifi card.
Thank you very much. With the help of an Ethernet cable I was able to download driver and now I have WiFi.
Best regards
That’s some good news. Enjoy
A post was split to a new topic: Getting Wi-Fi drivers for XPS13 on Ubuntu 20.04
