Nvidia driver issue
Nvidia driver isn’t installed correctly and can’t find the problem, how can I repair this?
after reinstallation still have the same issue
Could you please describe tbe problem, and the way you installed the driver?
And what system is it about?
nvidia-smi
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
followed the commands again and the same problem:
sudo apt-get purge nvidia-*
sudo apt-get install nvidia-driver-390=390.157-0ubuntu0.22.04.2
sudo dkms autoinstall
sudo reboot
lsmod | grep nvidia
The system:
System:
Kernel: 5.15.0-91-generic x86_64 bits: 64 compiler: gcc v: 11.4.0 Desktop: Cinnamon 5.8.4
tk: GTK 3.24.33 wm: muffin dm: LightDM Distro: Linux Mint 21.2 Victoria base: Ubuntu 22.04 jammy
dpkg --list | grep nvidia
cat /var/log/dpkg.log | grep nvidia
ii libnvidia-cfg1-390:amd64 390.157-0ubuntu0.22.04.2 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-390 390.157-0ubuntu0.22.04.2 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-390:amd64 390.157-0ubuntu0.22.04.2 amd64 NVIDIA libcompute package
ii libnvidia-compute-390:i386 390.157-0ubuntu0.22.04.2 i386 NVIDIA libcompute package
rc libnvidia-compute-525:amd64 525.147.05-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
ii libnvidia-decode-390:amd64 390.157-0ubuntu0.22.04.2 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-390:i386 390.157-0ubuntu0.22.04.2 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-390:amd64 390.157-0ubuntu0.22.04.2 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-390:i386 390.157-0ubuntu0.22.04.2 i386 NVENC Video Encoding runtime library
ii libnvidia-fbc1-390:amd64 390.157-0ubuntu0.22.04.2 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-390:i386 390.157-0ubuntu0.22.04.2 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-390:amd64 390.157-0ubuntu0.22.04.2 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-390:i386 390.157-0ubuntu0.22.04.2 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-ifr1-390:amd64 390.157-0ubuntu0.22.04.2 amd64 NVIDIA OpenGL-based Inband Frame Readback runtime library
ii libnvidia-ifr1-390:i386 390.157-0ubuntu0.22.04.2 i386 NVIDIA OpenGL-based Inband Frame Readback runtime library
ii nvidia-compute-utils-390 390.157-0ubuntu0.22.04.2 amd64 NVIDIA compute utilities
ii nvidia-dkms-390 390.157-0ubuntu0.22.04.2 amd64 NVIDIA DKMS package
ii nvidia-driver-390 390.157-0ubuntu0.22.04.2 amd64 NVIDIA driver metapackage
ii nvidia-kernel-common-390 390.157-0ubuntu0.22.04.2 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-390 390.157-0ubuntu0.22.04.2 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.17.1 all Tools to enable NVIDIA’s Prime
ii nvidia-settings 510.47.03-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-390 390.157-0ubuntu0.22.04.2 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18.2 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-390 390.157-0ubuntu0.22.04.2 amd64 NVIDIA binary Xorg driver
2024-01-12 10:30:57 status installed libnvidia-ifr1-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 remove libnvidia-ifr1-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status half-configured libnvidia-ifr1-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status half-installed libnvidia-ifr1-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status config-files libnvidia-ifr1-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status not-installed libnvidia-ifr1-390:i386
2024-01-12 10:30:57 status installed libnvidia-fbc1-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 remove libnvidia-fbc1-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status half-configured libnvidia-fbc1-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status half-installed libnvidia-fbc1-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status config-files libnvidia-fbc1-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status not-installed libnvidia-fbc1-390:i386
2024-01-12 10:30:57 status installed libnvidia-gl-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 remove libnvidia-gl-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status half-configured libnvidia-gl-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status half-installed libnvidia-gl-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status config-files libnvidia-gl-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status not-installed libnvidia-gl-390:i386
2024-01-12 10:30:57 status installed libnvidia-encode-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 remove libnvidia-encode-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status half-configured libnvidia-encode-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status half-installed libnvidia-encode-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status config-files libnvidia-encode-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status not-installed libnvidia-encode-390:i386
2024-01-12 10:30:57 status installed libnvidia-decode-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 remove libnvidia-decode-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status half-configured libnvidia-decode-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status half-installed libnvidia-decode-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status config-files libnvidia-decode-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:57 status not-installed libnvidia-decode-390:i386
2024-01-12 10:30:58 status installed nvidia-driver-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 remove nvidia-driver-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-configured nvidia-driver-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-installed nvidia-driver-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status config-files nvidia-driver-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status not-installed nvidia-driver-390:amd64
2024-01-12 10:30:58 status installed xserver-xorg-video-nvidia-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 remove xserver-xorg-video-nvidia-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-configured xserver-xorg-video-nvidia-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-installed xserver-xorg-video-nvidia-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status config-files xserver-xorg-video-nvidia-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status not-installed xserver-xorg-video-nvidia-390:amd64
2024-01-12 10:30:58 status installed libnvidia-cfg1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 remove libnvidia-cfg1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-configured libnvidia-cfg1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-installed libnvidia-cfg1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status config-files libnvidia-cfg1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status not-installed libnvidia-cfg1-390:amd64
2024-01-12 10:30:58 status installed libnvidia-ifr1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 remove libnvidia-ifr1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-configured libnvidia-ifr1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-installed libnvidia-ifr1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status config-files libnvidia-ifr1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status not-installed libnvidia-ifr1-390:amd64
2024-01-12 10:30:58 status installed libnvidia-gl-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 remove libnvidia-gl-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-configured libnvidia-gl-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-installed libnvidia-gl-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status config-files libnvidia-gl-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status not-installed libnvidia-gl-390:amd64
2024-01-12 10:30:58 status installed libnvidia-common-390:all 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 remove libnvidia-common-390:all 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-configured libnvidia-common-390:all 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-installed libnvidia-common-390:all 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status config-files libnvidia-common-390:all 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status not-installed libnvidia-common-390:all
2024-01-12 10:30:58 status installed libnvidia-encode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 remove libnvidia-encode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-configured libnvidia-encode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-installed libnvidia-encode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status config-files libnvidia-encode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status not-installed libnvidia-encode-390:amd64
2024-01-12 10:30:58 status installed libnvidia-decode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 remove libnvidia-decode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-configured libnvidia-decode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-installed libnvidia-decode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status config-files libnvidia-decode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status not-installed libnvidia-decode-390:amd64
2024-01-12 10:30:58 status installed nvidia-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 remove nvidia-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-configured nvidia-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-installed nvidia-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status config-files nvidia-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status not-installed nvidia-utils-390:amd64
2024-01-12 10:30:58 status installed libnvidia-compute-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status installed libnvidia-compute-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 remove libnvidia-compute-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-configured libnvidia-compute-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-installed libnvidia-compute-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status config-files libnvidia-compute-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status installed libnvidia-fbc1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 remove libnvidia-fbc1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:58 status half-configured libnvidia-fbc1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:59 status half-installed libnvidia-fbc1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:59 status config-files libnvidia-fbc1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:59 status not-installed libnvidia-fbc1-390:amd64
2024-01-12 10:30:59 status installed nvidia-settings:amd64 510.47.03-0ubuntu1
2024-01-12 10:30:59 remove nvidia-settings:amd64 510.47.03-0ubuntu1
2024-01-12 10:30:59 status half-configured nvidia-settings:amd64 510.47.03-0ubuntu1
2024-01-12 10:30:59 status half-installed nvidia-settings:amd64 510.47.03-0ubuntu1
2024-01-12 10:30:59 status config-files nvidia-settings:amd64 510.47.03-0ubuntu1
2024-01-12 10:30:59 status installed nvidia-compute-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:59 remove nvidia-compute-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:59 status half-configured nvidia-compute-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:59 status half-installed nvidia-compute-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:59 status config-files nvidia-compute-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:59 status installed nvidia-dkms-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:59 remove nvidia-dkms-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:30:59 status half-configured nvidia-dkms-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:04 status half-installed nvidia-dkms-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:04 status config-files nvidia-dkms-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:04 status installed nvidia-kernel-common-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:04 remove nvidia-kernel-common-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:04 status half-configured nvidia-kernel-common-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:04 status half-installed nvidia-kernel-common-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:04 status config-files nvidia-kernel-common-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:04 status installed nvidia-kernel-source-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:04 remove nvidia-kernel-source-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:04 status half-configured nvidia-kernel-source-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:04 status half-installed nvidia-kernel-source-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:04 status config-files nvidia-kernel-source-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:04 status not-installed nvidia-kernel-source-390:amd64
2024-01-12 10:31:04 status installed nvidia-prime:all 0.8.17.1
2024-01-12 10:31:04 remove nvidia-prime:all 0.8.17.1
2024-01-12 10:31:04 status half-configured nvidia-prime:all 0.8.17.1
2024-01-12 10:31:04 status half-installed nvidia-prime:all 0.8.17.1
2024-01-12 10:31:04 status config-files nvidia-prime:all 0.8.17.1
2024-01-12 10:31:04 remove libnvidia-compute-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:04 status half-configured libnvidia-compute-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:04 status half-installed libnvidia-compute-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:04 status config-files libnvidia-compute-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:20 purge nvidia-dkms-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:20 status config-files nvidia-dkms-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:20 status not-installed nvidia-dkms-390:amd64
2024-01-12 10:31:20 purge nvidia-prime:all 0.8.17.1
2024-01-12 10:31:20 status config-files nvidia-prime:all 0.8.17.1
2024-01-12 10:31:20 status not-installed nvidia-prime:all
2024-01-12 10:31:20 purge nvidia-kernel-common-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:20 status config-files nvidia-kernel-common-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:20 status not-installed nvidia-kernel-common-390:amd64
2024-01-12 10:31:20 purge libnvidia-compute-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:20 status config-files libnvidia-compute-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:20 status not-installed libnvidia-compute-390:amd64
2024-01-12 10:31:20 purge libnvidia-compute-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:20 status config-files libnvidia-compute-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:20 status not-installed libnvidia-compute-390:i386
2024-01-12 10:31:20 purge nvidia-settings:amd64 510.47.03-0ubuntu1
2024-01-12 10:31:20 status config-files nvidia-settings:amd64 510.47.03-0ubuntu1
2024-01-12 10:31:20 status not-installed nvidia-settings:amd64
2024-01-12 10:31:20 purge nvidia-compute-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:20 status config-files nvidia-compute-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:31:20 status not-installed nvidia-compute-utils-390:amd64
2024-01-12 10:40:41 install libnvidia-cfg1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:41 status half-installed libnvidia-cfg1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:41 status unpacked libnvidia-cfg1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:41 install libnvidia-common-390:all 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:41 status half-installed libnvidia-common-390:all 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:41 status unpacked libnvidia-common-390:all 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:41 install libnvidia-compute-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:41 status half-installed libnvidia-compute-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:42 status unpacked libnvidia-compute-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:42 install libnvidia-compute-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:42 status half-installed libnvidia-compute-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:42 status unpacked libnvidia-compute-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:42 install libnvidia-decode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:42 status half-installed libnvidia-decode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:42 status unpacked libnvidia-decode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:42 install libnvidia-decode-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:42 status half-installed libnvidia-decode-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:42 status unpacked libnvidia-decode-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:42 install libnvidia-encode-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:42 status half-installed libnvidia-encode-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:42 status unpacked libnvidia-encode-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:43 install libnvidia-encode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:43 status half-installed libnvidia-encode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:43 status unpacked libnvidia-encode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:43 install libnvidia-fbc1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:43 status half-installed libnvidia-fbc1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:43 status unpacked libnvidia-fbc1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:43 install libnvidia-fbc1-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:43 status half-installed libnvidia-fbc1-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:43 status unpacked libnvidia-fbc1-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:43 install libnvidia-gl-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:43 status half-installed libnvidia-gl-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:44 status unpacked libnvidia-gl-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:44 install libnvidia-gl-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:44 status half-installed libnvidia-gl-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:44 status unpacked libnvidia-gl-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:44 install libnvidia-ifr1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:44 status half-installed libnvidia-ifr1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:44 status unpacked libnvidia-ifr1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:44 install libnvidia-ifr1-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:44 status half-installed libnvidia-ifr1-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:44 status unpacked libnvidia-ifr1-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:44 install nvidia-compute-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:44 status half-installed nvidia-compute-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:44 status unpacked nvidia-compute-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:44 install nvidia-kernel-source-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:44 status half-installed nvidia-kernel-source-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status unpacked nvidia-kernel-source-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 install nvidia-kernel-common-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status half-installed nvidia-kernel-common-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status unpacked nvidia-kernel-common-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 install nvidia-dkms-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status half-installed nvidia-dkms-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status unpacked nvidia-dkms-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 install nvidia-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status half-installed nvidia-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status unpacked nvidia-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 install xserver-xorg-video-nvidia-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status half-installed xserver-xorg-video-nvidia-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status unpacked xserver-xorg-video-nvidia-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 install nvidia-driver-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status half-installed nvidia-driver-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status unpacked nvidia-driver-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 install nvidia-prime:all 0.8.17.1
2024-01-12 10:40:45 status half-installed nvidia-prime:all 0.8.17.1
2024-01-12 10:40:45 status unpacked nvidia-prime:all 0.8.17.1
2024-01-12 10:40:45 install nvidia-settings:amd64 510.47.03-0ubuntu1
2024-01-12 10:40:45 status half-installed nvidia-settings:amd64 510.47.03-0ubuntu1
2024-01-12 10:40:45 status unpacked nvidia-settings:amd64 510.47.03-0ubuntu1
2024-01-12 10:40:45 configure nvidia-prime:all 0.8.17.1
2024-01-12 10:40:45 status half-configured nvidia-prime:all 0.8.17.1
2024-01-12 10:40:45 status installed nvidia-prime:all 0.8.17.1
2024-01-12 10:40:45 configure nvidia-kernel-common-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status half-configured nvidia-kernel-common-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status installed nvidia-kernel-common-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 configure nvidia-kernel-source-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status half-configured nvidia-kernel-source-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status installed nvidia-kernel-source-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 configure libnvidia-compute-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status unpacked libnvidia-compute-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status half-configured libnvidia-compute-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status installed libnvidia-compute-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 configure libnvidia-compute-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status unpacked libnvidia-compute-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status half-configured libnvidia-compute-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status installed libnvidia-compute-390:i386 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 configure libnvidia-common-390:all 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status unpacked libnvidia-common-390:all 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status half-configured libnvidia-common-390:all 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 status installed libnvidia-common-390:all 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:45 configure nvidia-settings:amd64 510.47.03-0ubuntu1
2024-01-12 10:40:46 status half-configured nvidia-settings:amd64 510.47.03-0ubuntu1
2024-01-12 10:40:46 status installed nvidia-settings:amd64 510.47.03-0ubuntu1
2024-01-12 10:40:46 configure nvidia-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:46 status unpacked nvidia-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:46 status half-configured nvidia-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:46 status installed nvidia-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:46 configure libnvidia-fbc1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:46 status unpacked libnvidia-fbc1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:46 status half-configured libnvidia-fbc1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:46 status installed libnvidia-fbc1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:46 configure nvidia-compute-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:46 status unpacked nvidia-compute-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:46 status half-configured nvidia-compute-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:46 status installed nvidia-compute-utils-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:46 configure libnvidia-cfg1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:46 status unpacked libnvidia-cfg1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:46 status half-configured libnvidia-cfg1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:46 status installed libnvidia-cfg1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:46 configure nvidia-dkms-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:46 status unpacked nvidia-dkms-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:40:46 status half-configured nvidia-dkms-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 status installed nvidia-dkms-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 configure libnvidia-decode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 status unpacked libnvidia-decode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 status half-configured libnvidia-decode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 status installed libnvidia-decode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 configure libnvidia-gl-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 status unpacked libnvidia-gl-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 status half-configured libnvidia-gl-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 status installed libnvidia-gl-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 configure libnvidia-encode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 status unpacked libnvidia-encode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 status half-configured libnvidia-encode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 status installed libnvidia-encode-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 configure libnvidia-ifr1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 status unpacked libnvidia-ifr1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 status half-configured libnvidia-ifr1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 status installed libnvidia-ifr1-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 configure xserver-xorg-video-nvidia-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 status unpacked xserver-xorg-video-nvidia-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 status half-configured xserver-xorg-video-nvidia-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 status installed xserver-xorg-video-nvidia-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 configure nvidia-driver-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 status unpacked nvidia-driver-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 status half-configured nvidia-driver-390:amd64 390.157-0ubuntu0.22.04.2
2024-01-12 10:41:00 status installed nvidia-driver-390:amd64
Is there a reason you try to install that way?
What card do you have?
@kovacslt
42:00.0 VGA compatible controller: NVIDIA Corporation GF119 [NVS 315] (rev a1)
No, I tried apt-get install nvidia-driver-390 then I tried that way
@Fatima_Qasrawi
Very few Linux will still use the nvidia-390 driver, in most Linux the nouveau driver will have to be used to run the nvidia gpu. You can download and install the 390 driver manually, but it is not supported and it will not be updated.
Thank you, I switched to nouveau driver
drm_ttm_helper 16384 1 nouveau
ttm 86016 2 drm_ttm_helper,nouveau
drm_kms_helper 311296 1 nouveau
mxm_wmi 16384 1 nouveau
drm 622592 4 drm_kms_helper,drm_ttm_helper,ttm,nouveau
video 65536 1 nouveau
i2c_algo_bit 16384 2 igb,nouveau
wmi 32768 3 wmi_bmof,mxm_wmi,nouveau
I see, this is a very-very old card.
I think you’ll need to start over, and try to install the latest nvidia driver, that supports your card.
For that you may find some help here:
Alternatively keep the nouveau driver that works at least.
thank you, if I have problems with software installations, could it be due to the driver? and which is better to use Nouveau or Nvidia?
Generally I don’t think so.
Unless that software depends on something, that depends on proprietary nvidia driver.
If you just run regular desktop apps, I think nouveau is sufficient.
From the proprietary driver I’d expect some better performance in games, but as you card seems to be about 13 years old, performance cannot be the main point anyway.
I use it for drawing and simulation software, mainly Comsol multiphysics.
should I change the card or any suggestions for this?
@Fatima_Qasrawi
I changed from and old nvidia card to a new AMD card
There were some issues with the new AMD card being too new for some distros (particularly Debian)… I just moved to a distro (MX Ahs) that supported it.
That problem has disappeared with time… all distros support it now.
I would recommend an AMD graphics card. They dont drop support for old cards. Nvidia do drop support as cards age… that is your problem… it was my problem too.
This seems to be a Windows software, and I have no access to it, there’s not even a trial version to download.
So I cannot tell you.
If that thing works, for you just use it.
If it works, but too slow, get newer hardware.
I say newer hardware, because I assume, if your video card is that old, probably the rest of the system is similarly outdated. Isn’t it?
So if you have an aging motherboard+CPU, buying a more recent video card alone may be a waste of your money, probably all components would need some upgrade.
But if it works OK for you, just keep it using as is.
They do. Just try to get “factory” drivers for a Radeon HD7000 which is similar aged as that old nvidia: they dont have it:
https://www.amd.com/en/support/graphics/amd-radeon-hd/amd-radeon-hd-7000-series/amd-radeon-hd-7850
Difference is that AMD is much more open-minded from the scratch, and the Linux-native opensource drivers work way much better than those for any nvidia.
So that means, kernel developers do support old AMD cards way much better.
It was a kernel change that caused my problem. The kernel
developers changed the way driver modules interfaced to the kernel. Nvidia refused to update all its old drivers to to match
the new kernel interface. AMD did update its drivers, and they are open source anyway so anyone could do it.
It would seem like @Fatima_Qasrawi is in need of running Windows, Windows/Nvidia still supports my old Nvidia cards.
That is true. Nvidia is only a problem with Linux and BSD… or more correctly with Open Source…
Not sure about MacOS.?
But I have AMD Ryzen Threadripper 2990WX
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Address sizes: 43 bits physical, 48 bits virtual
Byte Order: Little Endian
CPU(s): 64
On-line CPU(s) list: 0-63
Vendor ID: AuthenticAMD
Model name: AMD Ryzen Threadripper 2990WX 32-Core Processor
CPU family: 23
Model: 8
Thread(s) per core: 2
Core(s) per socket: 32
Socket(s): 1
Stepping: 2
Frequency boost: enabled
CPU max MHz: 3000.0000
CPU min MHz: 2200.0000
BogoMIPS: 5999.28
here is what I have with details:
CPU(s): 64
CPU family: 23
Model: 8
Socket(s): 1
Stepping: 2
BogoMIPS: 5999.28
kernel: 5.15.0-91-generic x86_64 bits: 64
Machine:
Type: Desktop Mobo: Micro-Star model: X399 GAMING PRO CARBON AC (MS-7B09)
v: 1.0 serial: UEFI: American Megatrends v: 1.D6
date: 02/05/2021
CPU:
Info: 8-core model: AMD Ryzen Threadripper 2990WX bits: 64 type: MT MCP MCM
arch: Zen+ rev: 2 cache: L1: 3 MiB L2: 16 MiB L3: 64 MiB
Speed (MHz): avg: 1728 high: 1942 min/max: 2200/3000 boost: enabled
cores: 1: 1651 2: 1766 3: 1736 4: 1681 5: 1721 6: 1722 7: 1722 8: 1720
9: 1822 10: 1721 11: 1720 12: 1721 13: 1721 14: 1720 15: 1720 16: 1718
17: 1722 18: 1721 19: 1718 20: 1885 21: 1720 22: 1719 23: 1720 24: 1720
25: 1721 26: 1721 27: 1718 28: 1719 29: 1721 30: 1717 31: 1719 32: 1708
33: 1710 34: 1732 35: 1942 36: 1719 37: 1692 38: 1813 39: 1716 40: 1721
41: 1722 42: 1720 43: 1718 44: 1718 45: 1723 46: 1720 47: 1721 48: 1721
49: 1723 50: 1720 51: 1723 52: 1739 53: 1722 54: 1721 55: 1720 56: 1720
57: 1724 58: 1720 59: 1720 60: 1722 61: 1721 62: 1722 63: 1723 64: 1721
bogomips: 383953
Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Graphics:
Device-1: NVIDIA GF119 [NVS 315] vendor: Hewlett-Packard driver: N/A
bus-ID: 42:00.0
Display: x11 server: X.Org v: 1.21.1.4 driver: X: loaded: nouveau,vesa
unloaded: fbdev,modesetting gpu: N/A resolution: 1024x768~76Hz
OpenGL: renderer: llvmpipe (LLVM 15.0.7 256 bits)
v: 4.5 Mesa 23.0.4-0ubuntu1~22.04.1 direct render: Yes
Audio:
Device-1: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 0b:00.3
Device-2: NVIDIA GF119 HDMI Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 42:00.1
Sound Server-1: ALSA v: k5.15.0-91-generic running: yes
Sound Server-2: PulseAudio v: 15.99.1 running: yes
Sound Server-3: PipeWire v: 0.3.48 running: yes
Network:
Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel port: 1000 bus-ID: 08:00.0
IF: enp8s0 state: down mac: 30:9c:23:64:e6:b0
Device-2: D-Link DWA-131 Wireless N Nano Adapter (Rev. E1) [Realtek
Drives:
Local Storage: total: 476.94 GiB used: 21.56 GiB (4.5%)
ID-1: /dev/nvme0n1 vendor: Seagate model: XPG GAMMIX S11 Pro
size: 476.94 GiB temp: 42.9 C
Partition:
ID-1: / size: 466.95 GiB used: 21.55 GiB (4.6%) fs: ext4 dev: /dev/dm-0
mapped: vgmint-root
ID-2: /boot/efi size: 511 MiB used: 6.1 MiB (1.2%) fs: vfat
dev: /dev/nvme0n1p1
Swap:
ID-1: swap-1 type: partition size: 980 MiB used: 0 KiB (0.0%)
dev: /dev/dm-1 mapped: vgmint-swap_1
Sensors:
System Temperatures: cpu: 52.1 C mobo: N/A
Fan Speeds (RPM): N/A
Info:
Processes: 789 Uptime: 18h 12m Memory: 62.74 GiB used: 3.92 GiB (6.2%)
Init: systemd runlevel: 5 Compilers: gcc: 11.4.0 Packages: 2285 Shell: Bash
v: 5.1.16 inxi: 3.3.13
:astonished:
Woooow!!!
How did you get that shitty old nvidia card into that threadripper system?
:smiley:
Ger a more recent -maybe AMD- videocard and you’ll be hapoy.
